Re: Magnavox 32md359b/f7 White Screen and with sound only
OK can you test the voltage on it relative to chassis ground.
I think it's pin 5 you should be testing.
Just be careful you're not transposing it with ground, as they are symmetrical.
Are you seeing anything on the LCD+16V pins? Hmm, maybe it is a PSU fault after all. I will trace where INV 16V is generated.
It looks like it's generated from the LCD 16V supply which is protected possibly by an overvoltage protector - it's hard to tell from the schematic, but if LCD 16V is missing, then you will not get power for the inverters.
Yes. I am working from it when I give you suggestions.
My guess is then the main/digital board, which is where troubleshooting gets tricky.
Although I never asked, but what is it in standby? Some TVs use inverse logic where a high signal indicates backlight off.
What I mean is, what is the pin you are testing measuring when the TV is off (in standby mode.)
So it would appear to my limited eye that the main board isn't switching on the backlight (or it is switching it off quickly) which is unusual. Can you post a picture of the connector you are testing, I need to double check it is being tested properly.
Oh, I didn't expect that. I thought it would be some kind of multi-wire connector but it's flat flex.
Can you see an R1035, or R1036, or Q1005 on the top side? They will probably be near that connector you have been probing, on the inverter side.
