A friend brought over a 1800FP monitor he got from the flee market. When you put power to the monitor the green light comes on but there is no image on the screen. If i shine a flashlight on the screen there is not even a faint image on the screen.
I have an 1800FP monitor that i use on my computer but i took it apart to help my friend fix his monitor. So i have a working 1800FP for comparison.
What i did was the following:
To help identify what was causing the problem i disconnected the inverter board and had only the power supply board and the logic board connected. I measured the voltage differences at the connectors. I actually found a difference.
Looking at the enclosed pic you will find two letter "A". One at the connector between the logic board and the inverter board. One at the "+" side of a capacitor. I was measuring the voltages at all the caps and comparing those measurements at the same locations on the "good" monitor. I found that the points labeled with the "A" are at the same "node".
On the good monitor the voltage is a constant ~ 0.034V. WHile on the "bad" monitor the voltage is constant 3.1V.
Any ideas? I think the logic board is "bad" but what i dont know is if the bad component is something i can replace or not. Any ideas how to narrow it down.
I know i could put the good logic board on what i suspect to be the bad logic board but i dont want to do this just yet because i dont wnat to "kill" my monitor as well.
Any thoughts?
Any thoughts?
