I've noticed some boards are a pain to desolder, and others the solder melts quite readily. This is of course already considering large ground planes that will suck up all the heat from the joint. This by itself is a pain (do people just keep on applying heat to desolder caps on large ground planes or have some other tricks?)
Take for instance my Antec SP400 PSU, the solder on the board took forever to melt. After I doped the solder on the board with some fresh eutectic 63/37 (or some high tin solder) it melted much more readily than before.
Is it ROHS solder that's doing this? anyone know the exact formulation of common high melting point solder (metal ratios?)
Then if you encounter this stuff, do you just use a really high watt iron to melt through it, or use a moderate iron and let it sit there till it melts (and for both, ever cause damage to board or components?)
I have a spool of ROHS solder from Harbor Freight which I believe is mostly tin with a little copper in it, and has rosin core. This stuff melts more readily than the SP400 solder... (Then the other question is if the HFT ROHS solder is really lead free or not...) Also cheap 60/40 solder seems to melt faster than the SP400 solder... *shrug*
