Samsung UE32D5500 Nand flash dump need.
    i am looking for nand flash dump for Samsung tv D5500 series.
    Thank you in advance to all.
    N.
    Re: Samsung UE32D5500 Nand flash dump need.
    maybe this?
    https://translate.google.co.uk/trans...f/&prev=search
      Thank you very much, but this file need payment. I am looking for free.
        Sorry i did not check the link fully to see if it was free etc
          Anyone can help?
            did you check this thread? sorry i cant as just going out
            https://www.badcaps.net/forum/showthread.php?t=59877
            Have you tried freeze spraying the old eeprom ic as this sometimes lets the tv start up if this then works ok you can remove the ic put into a reader re freeze the ic and read it then save data and re write too a new ic
              i have just dumped my defective nand it's large size almost 2Gb but now i need working dump.
                Maybe can help someothers in future
                https://mega.nz/#!IS5SiSCb
                  The link does not work says you need a key to open the file?
                    Let me check, I haven't put any decryption key
                      What are you using to program the nand, which programmer ?
                        https://mega.nz/#!IS5SiSCb!Hc2EQyEx0...dVRg6A09MIgQY4
                          mine programmer is SmartPro 5000U-Plus
                            Please use second link, advice me if there are problems.
                            Have a nice Sunday
                              Have a nice Sunday
                              Hi the second link works fine so thanks for sharing the dump ive just downloaded the file, so does the tv in question work ok now.
                                http://televid-sib.ru/
                                http://televid-sib.ru/index.php?board=416.0
                                http://televid-sib.ru/index.php?board=796.0
                                  Thanks thats looks like a good forum for firmware etc so i have just joined it
                                    Great
                                      I will flash Nand tomorrow, and advice. Now TV is continually reboot.
                                        Sorry for delay but still not solved the problem. Or the dump is not good or I male mistake during program nand. I am investigate and asap solve (hope) advice you. Would be good if anyone was sure 100% of working dump.
