the tv still works if I dettached those connectors on the psu board and then reconnect it for about 2 days wherein the standby light will appear again and tv works normally but unfortunately after 2 days of using it ,standby light doesn't show again.This is actually a recurring problem.
However, i already replaced out of tolerance capacitors, checked resistors but i found something unusual when I diode checked(D904 ) with part no.SR204 Shottkey 2A 40V. My reading shows .000001v on both sides of the diode for in--circuit diode test. however,there's a resistance if I checked it and not shorted as well.As I removed and checked it i found the diode test fwd voltage to be 0.1596v. Can this be the problem? because in the datasheet it should be 0.5v.
If I substitute different shottkey diodes,still my reading shows .000001v on both sides of the diode. I don't know if the problem is in the OVP of slc1012c and I don't have schematics.
hope you can help me.
