problem with wasmachine SMS43M12EU
    i friend i have problem with bosch dishwasher SMS43M12EU
    the problem when i choose the menu i start it after one minute the menu stop and the logo of water is on has there is no water coming
    can you help or some documentation
    i check the water coming from the source i clean the filter from water source
    any idea thanx a lot
    Re: problem with wasmachine SMS43M12EU
    You will want to check the water feed line for kinks when the unit is pushed back in this can sometimes happen, after that you will need to look at the water fill valve(s) and check function.
      check the fault codes .
      http://www.espares.co.uk/advice/care...or-fault-codes
