sd sandisk 2gb delete does not work Tools?
    I try to erase my SD card does not work and in device manager and management have my SD card but not in the workplace
    many thanks
    Re: sd sandisk 2gb delete does not work Tools?
    did you try moving the write-protect switch a few times?
      Did you also try SD formatter?
      https://www.sdcard.org/downloads/index.html
        Has anyone actually had success with the SD card formatter utility, versus just dumping all zeros to the device in, say, Linux?
          Ive had better luck zeroing with Linux. Otherwise, using SPI mode and zeroing it that way has worked as well
          Follow the white rabbit.
