I have acquired a non-functional Vizio M50-C1. Previous posts have revealed higher than expected voltages on the 12v pins (recorded at 19v). Mine is the same. LED on main board illuminates when plugged in as solid red. When powering up, it changes to red and blue. The power indicator comes on then fades out as normal. Nothing displayed on the screen even with the flashlight test. No backlights at any time. Remote functions, turning the TV on and off. Power will cycle about every two minutes. From my reading of others before me, it appears to be a short in the main board. Replacing the board will run about $60 plus shipping. Trying to eliminate any other possibilities before I spend the bucks. Pictures can be posted if required.
Vizio M50-C1 Nothing on screen, no backlights
Re: Vizio M50-C1 Nothing on screen, no backlights
See this link: https://www.badcaps.net/forum/showth...t=Vizio+M50-C1Never stop learning
Originally posted by Skipper14 View PostI have read that post at least five times before creating an account and posting my query. I'm fairly confident it's the main board but was looking for any other possible test methods I could try to confirm. Thanks.
Your photo does nothing to assist.
https://www.badcaps.net/forum/showthread.php?t=76708
Guys, thanks for the participation. Decided to just get the replacement board and TV is now functional. Would like to know more about deep diving on these boards to identify the faulty part. That probably takes more electronics education than I have been exposed to. Will continue to improve and try new things. On to the next one.....Thanks.
Looks like Mxx-C1 series suffers from BGA failures of the lead free solder balls used on the main processor that crack over time. This problem affects LG LV series, LG LS series, laptops, Xboxes and PS3's. If you took a hair dryer to the processor before plugging it in, then it should have expanded the joints enough to make contact and start up the tv to confirm the failure.
