ESR meter for a novice
This topic is closed.
    Re: ESR meter for a novice
    I'm sorry but i have to back up devid21 on this one - i have designed a PCB for the same meter, built it, and it works just fine. It IS accurate enough on a larger meter movement such as that found in older multimeters, besides, if you feel you need more accuracy, you can always hook a DMM set on the 200mV scale in parallel with the analog meter. Then all you need is to make a nifty table to decode the DMM's voltage reading into resistance values.
    I can notice bad caps even when operating it into a VU meter, because when the cap is in good condition, measuring it is accompanied by a rewarding click sound as the meter hits the peg due to overshoot. If the cap is anything less than perfect, the meter won't click even if it does go full scale.
    A working TV? How boring!
      Don't get your tools from Playschool.
      The upper and lower ends of the movement are inaccurate and being more precise doesn't make it more accurate.
      Mann-Made Global Warming.
      - Dr Seuss
        Sorry,Bob,the scheme from a russian site
        On other sites have long been ampty.
        If you have time,make this ESR meter
        It measure on the sine wave.
        The lower limit of measurement:20-30 milliohms
        Com you compare with your ESR meter.
        Good luck
        http://www.remserv.ru/cgi/magazine/i...1/measure/1855
          Originally posted by devid21 View Post
          Rus Mike wrote:
          The criteria is about-more than 1000uF-ESR<0,1ohm,100-1000uF-0,2-0,5ohm is normal.
          In that case Rus Mike doesn't know his ass from a hole in the ground.
          - Dr Seuss
            Good luck
            Huh?
              Originally posted by smason View Post
              Huh?
              Ignore that one. He's just a twit that doesn't know what low ESR is, yet, he insists on handing out advice about how to measure it.
              - Dr Seuss
                Before you send a message,check your ass.
                  OK, I've done that. Now what?
                  It is a good shrubbery. I like the laurels particularly...
                    ROFL!! I just sprayed coffee on my keyboard.
                      Don't need to.
                      I know where mine is.
                      - Dr Seuss
                        And why do you ask to send its meter?
                        Can you also imagine ordered?
                        Do i need this digital toys?
                        A simple analog ESR meter does too.
                          You can check the capacitors without measuring ESR.
                          http://members.iinet.net.au/~geoffg/Measuring_ESR.html
                            I'm delighted that someone here understood what I meant. I hope your keyboard's OK.
                              Further evidence you are a clueless wonder.
                              Yes, you can check caps without measuring ESR,,
                              - however, you won't know if the caps are any good.
                              The link you provided shows how to measure ESR with an o'scope.
                              He -IS- measuring ESR.
                              - But with equipment MORE expensive than an ESR meter.
                              The whole point of having an ESR meter is to avoid needing a scope to check ESR. - DUH!
                              - Dr Seuss
                                Definitively understood here too Bob.
                                Didn't spray coffee, but did call the wife in to share it..
                                - Dr Seuss
                                  When you get better at English I might understand your imagined points/implications.
                                  There are currently NO commercially available or DIY plans/kits for an analog ESR meter that is capable of measuring ESR on low ESR caps.
                                  Th3_uN1Qu3's project in the other thread is interesting but what he is proving is that it costs more $$ in parts and time to build an analog ESR meter for low ESR than it would cost to just to buy a digital meter kit.
                                  - He's already spent much more $$ in hours lost than buying a kit would have cost.
                                  At this point he still doesn't have a working prototype and when he does it STILL won't be as accurate as a digital meter for low ESR.
                                  [Young people with no real worldly responsibilities are like that. I know, I was one of them once.]
                                  - Dr Seuss
                                    Designers for children(KIT) had never used
                                    All ESR meters always do myself.
                                    And who are you do this to give me advice?
                                      You have repeatedly demonstrated that you have no idea what Low ESR even is.
                                      Your ESR meters are for General Purpose caps and you repeatedly recommend such meters for Low ESR measurements.
                                      - That doesn't work.
                                      If you are going to participate on a site that's primary 'theme' is Low ESR applications then you should at least learn what Low ESR it is and refrain from handing out advice until you understand it.
                                      - Dr Seuss
                                        When do at least one ESR meter with his hands,then continue the discussion.
                                          I have.
                                          - Dr Seuss
