Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Im wondering if anyone out there has a nand dump for ic1302 fpr a PN59d6500df00
      model tv? main?
        Hi, guys. I have here TV Nordmende NM40125DLED. It keeps restarting all the time. I think that reset to factory settings should resolve this problem. Any chance to reset by USB with firmware? Or to flash U10 and U12? If anyone, you guys, has a possibility to help me, please help me
        Board: 17MB82S
        Panel number on the pictures (don't know which one it is)
        Thank you in advance for any help.
        Regards
          Board: 17MB82S
          Regards
          try
            Originally posted by dani502017 View Post
            model tv? main?
            Here's the numbers
            PN59d6500df00
              Evening
              On the lookout for firmware pls
              Tp.Vst56.pb801
              Panel:T390hvn04
              Or
              Tp.vst59.Pb813
              Panel:T390hvn04
              Thanks in advance
                try
                Thank you so much, dani502017, for your help. The TV started. All is good apart from the sound. Could be the problem related to not original software? Or the problem can be somewhere else? Thank you for any answer.
                  Does anyone have the EPROM dump u6 for this set,
                  Panel and main board are
                  ST3151A05-8 BOARD MS308C1-ZC01-01
                  Thanks David
                    Try another firmware
                      Where can I get it?
                        Where can I get it?
                        check the menu settings in the service menu, see which norm is set. Did you try out the headphones if you sound?
                          Where can I get it?
                          I can send you a firmware for your board but im not sure if its the correct screen/tuner/speaker etc etc. I can also get the correct firmware but I have to order it from my supplier.
                            I can send you a firmware for your board but im not sure if its the correct screen/tuner/speaker etc.
                            Send me, please. I will try
                              Does anyone have an Eeprom dump (or Dumps) for a Vizio E390-A1? There are 2 Eeproms on this mainboard. A Winbond 25Q64FVSIG at U409 and a 24C64F at U408. I believe my problem is with the Eeprom at U409.
                              Mainboard# TXCCB02K038
                              Panel# TPT390J1
                              Thanks in advance! Joey
                                I sent you the firmware
                                  It is not fair not to post here the software, maybe there are others who need it. Today I will not post anymore, I will send them by email.
                                  Merry Christmas everyone!
                                    Vestels firmware are very specific. I don't the screen/tuner/model/make. So I think its useless to post it here. I can post only the firmwares/dumps that im aware of their panel etc here.
                                      Thanks,dani502017, for your reply. Yes, I tried headphones-no sound at all. The speakers are good as well. All settings are OK. Looks like something wrong in mainboard or in the brain itself (U10 or U12 ?) ...
                                        Thank you,ducky29. Upgrade works as should. It was upgraded but still no sound anyway ...
