Lg oled55e6p-u.auswljr
    Ok guys...
    I got a good one for use
    I have a LG OLED55E6P-U TV. I pullin it in i get the standy light. Once i hit the power button, it blinks a few times and the standby light goes out...
    I have posted some pics and measurements.
    On the power board i get 3.5v- POWER/On after than 0 for the rest of the connector on the power board
    Re: Lg oled55e6p-u.auswljr
    search in this forum about LG OLED and download pdf how to test SMPS on bower board. must important don't forget make the test as PWB stand alone nothings connected to it MB neither T-CON and report your result
      ok i will..
      so this will work on all model OLED
        ok I did the power supply check using the OLED
        SMPT
        THE light bulb remained on....and lit.. so that mean the panel is bad...
        something weird... on the power supply i hot 24v to operate the light bulb test....
        but i checked P203 for 12 volts and nothing..
          my results from the power supply.pdf
            do you mean the test Nr 1 for power on short with STB you don't have 12 v on the socket ??
              On P203 on the power supply board there was no 12VT and that voltage comes from main board
              On P202 on the power supply board there was 24 VD
              Test 1 results
              1 and 3 jumpered
              1) 3.0v
              2) 0
              3) 3.5
              4) 3.7
              5 3.5
              6 gnd good
              7 3.5
              8 3.5
              9 gnd good
              10 gnd good
              11 12
              12 11.98
              13 12
              14 11.98
              15 12
              16 Gnd good
              17 Gnd good
              18 0
              19 23
              20 23
              21 23
              22 23
              23 Gnd good
              24 Gnd good
              Test 2
              2 and 5 jumpered
              24v on power supply ON
              P202 reads 24v on all the right pins and ground
              Test 2 cont
              P202 connected to T con board
              24v good
              Test 2
              1/ground and 8 /24v/connected to the Light bulb
              Light bulb remains lit
              So does this mean the Panel is bad?????
                it looks your PWB okay.
                when you do the test 2, the jumpered 1 and 3 at test 1 should be remain in place.
                bulb test if its remain lit. not always drive us the panel defect. you need now do those test one after and tell
                A- no jumper at all. all socket in place and trace the 12 volts and the 24 V on the socket which goes to main boards after you plug it to wall socket.. ( this test to check if MB send signal to turn on ) it may come the 12 / 24 reading for short time.
                B- do same test ( A ) .. but now only the LVDS between MB and T-Conn driver boards disconnected .. trace the 12 & 24 Volts and notice the time how long they remain on.
                C- PWB socket to MB disconnected ... the 2 jumper as Test 1 & 2 in place. and trace the 24 Volts on T-CON driver. notice any Temperature goes high... and follow the line of 24 on the boards.. if there some where Open area.
                D- ( Dirty Test do Only if Test A-B-C ) same result no change )
                same as Test 1 and test 2 together with jumpers between Stand by and power-On & Standby and Driver On. ( but the 2 wires which bring the signal from MB of Power On & DRV On should be terminated from the socket or just remark them and cut off at the middle ) you can later solder back
                with this Dirty forcing the LG to turn on... give eyes on the screen what you will have..
                  ok here we go..
                  Test A
                  - no 12v or 24v on main board
                  Test B
                  - no 12v or 24 v on the main board
                  Test C
                  - 24v on t-con board with set of jumpers in place.
                  i have not done Test D... dirty yet
                    from Test A & B we have here issue on MB. could you post clear photo on it from both side.. this model 55e6p don't know exactly the MB version & serial
                    BTW wait right now don't do the dirty one.
                      try to press the power on the set panel keep press and plug it in wall.. check the power on pin reading.
                        nothing after pressing power on the set
                        no 12 or 24 volts
                          no 12 or 24 volts
                          my last post wasn't to track 12 and 24 V on the socket ..... its about the 3.5 V which should the main boards send it to the power supply after plug it in
                            ok understood..
                            there was no 3.5v from the main board..
                              Im thinking there is a issue with the main board.
                              No 3.5 v from CPU...
                              i wish i had a schematic for main board thats always my weakness for these tv 's.. No schematics
                                i will test backlights with my led checker
                                  OLED doesn't have any LED backlight..
                                  go direct to the dirty test.. if it give asign go head to replace MB
                                    ok i will
                                      Performed dirty test with jumpers in and power on
                                      and Drv_on wire terminated at MB socket halfway.
                                      Test 1 all voltages the same on P2300 power supply
                                      Test 2
                                      24v on P202 on power supply
                                      Light bulb test.. light was bright and remained on
                                      so do you suggest a new main board
                                        funny thing..
                                        just checked this fuse on main board and it is blown
