My back lights were out, So I ordered new strips and installed them. After the TV was put back together and turned on, the right side of the TV works perfect (side of the LED strips connectors). The left side, is darker, yellow is dark yellow, red is dark red, and so on. Sometimes the TV looks good.
I used a backlight meter to check the LEDs after installing them in the TV. The Old led strips, has a voltage of 58volts. The new LED strips, (24 LEDs), has a voltage of 54volts. Also, when I removed the white papers, I lifted a corner and put take on them, and removed all of them as one. I also marked the corners, leftside top, rightside top.
Could the problem still be the white papers, or even the 2 filter on the bottom of the TV.
Any recommendation to look for when I take the TV back apart?
