Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 11-08-2018, 09:15 AM   #1
karmele
City & State: gasteiz,araba
My Country: spain
I'm a: Knowledge Seeker
Default Convert monitor ccfl to led
Hi all experts,
I will try to explain clearly what I want to do and the doubts I have.
This is a Viewsonic monitor for years that have broken the lamps and finding no replacement we have decided to put LED strips.
We have the DC / DC controller bought in Aliexpress that as you know comes with four cables (VIN, GROUND, ON / OFF AND DIM) to solder on the monitor board.
I have seen many videos and I have the general idea of ​​what to do but my doubt is that I can not find the right voltage to solder on the board the VIN cable. I only see 12V, 13V and 25V.
I explain what I have done so far:
VIN: I have soldered it to 25V in different places of the monitor board (I tested with 12 and 13V but they do not turn on the led) this connector board does not have the pin for VIN
GROUND: to pin ground on connector
ON / OFF: to pin ON / OFF of the connector that has 0.12V (is this enough voltage?)
DIM: to pin BRIGHT of the connector that has 3.28V
Well, what I have achieved is that I turn on the monitor that I have connected to the laptop, but the image I see is as if it had a lot of brightness but like fog, which means that the icons are not seen at all and what there is in the screen. I know I have not explained myself well and you will not understand me but it is difficult to explain.
So it is clear that somewhere I screwed up, either in the 25V of the VIN, either in the rest of voltages or maybe that as I read somewhere should have disconnected some mosfets and some capacitor on the board.
The help that I am asking for is that you tell me exactly where on the board I should solder the different wires of the regulator.
And this is where I ask for your help so you can guide me by giving me ideas and suggestions.
I send photos of the board on both sides, photos of the DC / DC controller, photo of the monitor model and also if you need I have the PDF of the monitor available.
Well, I thank all those experts who lend themselves to help.
Regards.
File Type: pdf viewsonic_vx2433wm-1_vx2433wm-cn-vs12324-.pdf (7.54 MB, 5 views)
karmele is offline   Reply With Quote
Old 11-08-2018, 10:53 AM   #2
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Default Re: Convert monitor ccfl to led
Where exactly did you connected to the location that is 25V?
ON / OFF: to pin ON / OFF of the connector that has 0.12V (is this enough voltage?) The ENA per your picture (https://www.badcaps.net/forum/attach...3&d=1541690110) is shown as 5V (more likely 2 ~3V may work), 0.12V is not going work. Does that ON/OFF pin of that Viewsonic stay at 0.12V and does not change state when you turn the monitor on and off and have it connected to running PC?
__________________
budm is offline   Reply With Quote
Old 11-08-2018, 12:43 PM   #3
karmele
My Country: spain
There are two mosfet on the board on the right side. The one above is 25V, the one below is 13V. I connected it to the one above.
The ON/OFF pin is 0.12 in standby but once I click power it goes to 2.80V with de PC connected.
The DIM pin is 3.28V but once I turn on it goes to 1.28V
One more thing, I would like to show you the picture that I took from the screen for you to see how it looks, like foggy.
How can I post a picture? I can not find the way.
Old 11-08-2018, 04:40 PM   #4
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Post the pictures the same as you did in post #1 , Click on Go Advanced - Click on the PAPER CLIP (next to the happy face) and attach your pictures
R_J is offline   Reply With Quote
Old 11-08-2018, 05:18 PM   #5
budm
budm's Avatar
My Country: USA
See attached picture for the VIN and GND connection to the LED driver board.
Old 11-08-2018, 06:16 PM   #6
karmele
My Country: spain
Thanks, I will try tomorrow morning. I hope it works.
I would like to add a couple of pictures for you guys to see how the screen monitor looks. Like I said before it seems like a foggy image.
Thanks again
Old 11-08-2018, 06:18 PM   #7
karmele
My Country: spain
Quote:
Thanks a lot.
Old 11-08-2018, 06:19 PM   #8
karmele
My Country: spain
Quote:
Thanks a lot. I did it.
Old 11-08-2018, 10:41 PM   #9
budm
budm's Avatar
My Country: USA
Thanks again
Did it look like that before you taken the LCD panel apart?
Are you able to dim the backlights level?
Old 11-09-2018, 07:15 PM   #10
karmele
My Country: spain
No, before taking the panel apart it looked OK.
Yes, I wired the DIM to 3.5V and I am able to dim the bright and contrast but no much. There is a slight difference from 0 to 100.
I tried what you proposed me yesterday and it keeps being the same, no changes.
Someone has proposed to me to lower the tension with a resistance of 10 ohms and 5 watts. He told me that that brightness could be due to the high voltage in VIN (25V).
I will keep you posted.
Regards.
Old 11-09-2018, 08:38 PM   #11
budm
budm's Avatar
My Country: USA
Regards.
Are you 100% sure that you put all filter, polarizer sheets for the LCD back together correctly, backlights will not cause that faded pictures to like that on the screen, it can also be due to bad Gamma Voltages.
Old 11-13-2018, 06:14 PM   #12
karmele
My Country: spain
I have disassembled and assembled everything again and everything remains the same.
I have observed a strange thing that has puzzled me. Measuring the input and output voltages to the inverter of the LEDs, I see that through the VIN wire enter 21V and 21V get out, so far so good. Now, I measure what goes into the monitor by means of the four wires (two pairs red and white) positive and negative, and I get positive 21 V and 15V negative , the same in the two pairs. Look at the photos of the inverter so you can clarify what wires I'm talking about.
I have a basic knowledge about electronics but, can you tell me why the negative gives 15 V positive? Is this OK?
Old 11-13-2018, 09:13 PM   #13
R_J
City & State: ☻
My Country: Canada
Full +21 volts is applied to the + of the led's. The negative side of the led is controlled to vary the current/brightness, in this case 15 volts above ground (difference is 6 volts to the led's)
I agree with budm, check the diffuser sheets, they need to be installed in the right order and the right direction.
Old 11-13-2018, 09:24 PM   #14
karmele
My Country: spain
So, I undertand it is OK? Can you explain to me with more details? I thought it could have something to do with my problem.
Thanks a lot.
Old 11-13-2018, 09:46 PM   #15
R_J
City & State: ☻
My Country: Canada
What would you like explained? The diffuser,polarizer and prism sheets behind the panel MUST be in the correct order and the correct direction, they are NOT just sheets of plastic.
There are usually 2 or more sheets
Did you keep all of them in order when you removed the lcd from the panel.
Maybe this will help explain https://pid.samsungdisplay.com/en/le.../lcd-structure
Old 11-14-2018, 04:22 AM   #16
karmele
My Country: spain
Hi again,
Yes, I have disassembled and assembled everything again and everything remains the same.
Thanks.
Old 11-14-2018, 04:28 AM   #17
karmele
My Country: spain
I was not asking you for details about the order of the sheets, but about the leds inverter voltages.
Thanks for your help.
Old 11-14-2018, 09:38 PM   #18
budm
budm's Avatar
My Country: USA
You need to look up the spec sheet of that LED driver IC, the spec sheet will usually gives application circuit which is most likely to match what you have on your board.
Old 11-15-2018, 05:53 AM   #19
karmele
My Country: spain
Hi again and thanks for helping me,
Well, the IC is DF6113 I attached a picture. Please can you guide me about reading the spec sheet? I do not have the knowledge to do it.
Thanks again.
Old 11-15-2018, 06:29 AM   #20
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
which way are you pointing the leds??
they should face towards the center of the panel - not forward.
stj is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
