Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Thread Tools Display Modes
Old 11-21-2021, 11:51 PM   #1
shovenose
Send Doge Memes
shovenose's Avatar
City & State: Vallejo, California
My Country: USA
I'm a: Forum Junkie
Default Best cheap way to cool AMD FirePro S7000?
Got these for a very attractive price, my problem is they are passively cooled and I need to find a way to cool them. The S7000 is pretty much identical to the FirePro W7000, except that it has less DisplayPorts and it's meant to be used in rackmount servers with noisy high CFM fans running at full blast all the time.
I was thinking laptop CPU fans but most of them are 5V and I was hoping for 12V so I could control them via software.
shovenose is offline   Reply With Quote
Old 11-22-2021, 12:14 AM   #2
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
I'm a: Professional Tech
Default Re: Best cheap way to cool AMD FirePro S7000?
Many of the 5v laptop fans can take 12v (I've done it a time or two diddling with things)...they naturally just spin faster....and for that, you'll probably need it....but FWIW, power it with 5v and leave it be.... It'll be quiet.
__________________
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is online now   Reply With Quote
Old 11-22-2021, 05:32 AM   #3
shovenose
Send Doge Memes
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
Hmm, ok, thanks. I ordered two matching ones that looked like a good fit off eBay. $10 each free shipping for name brand Sunon fan. For some sorta HP ProBook. Should be alright. I'll post how it turns out!
Old 11-22-2021, 08:08 AM   #4
Uranium-235
Derp
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
You know active display ports can be chained right? Or you can use a DP -> Multi HDMI converter
__________________
Uranium-235 is offline   Reply With Quote
Old 11-22-2021, 09:49 AM   #5
shovenose
Send Doge Memes
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
Quote:
For $50 for an adapter not worth it :'( hence why I ended up with two cards. I will simply put one monitor per card.
Old 11-22-2021, 12:17 PM   #6
desert-rat
City & State: Avondale AZ
My Country: USA
I'm a: Knowledge Seeker
2 fans in series, or use a dropping res.
desert-rat is offline   Reply With Quote
Old 11-22-2021, 01:38 PM   #7
shovenose
Send Doge Memes
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
Quote:
That's an idea too. Hmm. Will try just powering them directly from 5V if it's not noisy I'll leave it like that if it is you're right I could use a fan controller and put them in series. Smart!
Now I just hope my old Antec EA380D is up to the task of powering my computer with two 150W GPUs. Lol. I did reverse the 80mm fan on that PSU a long time ago because of the way it is in my case reverse airflow makes far more sense.
Old 11-22-2021, 03:21 PM   #8
Topcat
The Boss Stooge
Topcat's Avatar
Just a FYI, a ~50ohm resistor will get it about where you want if you're feeding it from the +12v rail.
Old 11-25-2021, 10:04 AM   #9
desert-rat
My Country: USA
Years ago my dad used a under dash evap with a 6v fan on a 12 v vec. ( late 60s ) he took some old nicrome wire from an old heater . He played with the lenth untill he got 6 v on thefan .
Old 11-30-2021, 10:09 AM   #10
shovenose
Send Doge Memes
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
Well, the laptop fans were fine in terms of cooling but way too loud at 5V :/ going to try a new approach...
Old 11-30-2021, 10:15 AM   #11
Topcat
The Boss Stooge
Topcat's Avatar
Quote:
That's actually a nice fit.
Old 12-04-2021, 08:40 AM   #12
shovenose
Send Doge Memes
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
Quote:
I know, it is definitely quite nice looking. Unfortunately it was just too noisy. I left that pretty but whiny solution on one of my cards and put it in one of my servers where it will be useful but noise doesn't matter. The one in my PC where noise does matter got this ugly solution. I JB-Welded some random old CPU cooler to it. The Noctua 80mm fan even at full blast is very quiet. Some fan noise is audible through the case but it's barely noticeably vs the screaming noise of that laptop fan. The downside is it now uses up four slots so not really useful long term as I had to ditch my USB 3.1 type-C card and my sound card.
Now that I have proof of concept and the dual displays work in a sort of hybrid GPU/passthrough setup through my Intel iGPU I'm going full steam on a better graphics card. Unfortunately I kinda failed to do my research beforehand (like usual, I seem to never learn) and the AMD S7000/W7000 doesn't support everything I need so I'm going with a Tesla M40 instead. The good thing is I can just put the ugly S7000 in my server and sell the other one I didn't hack up back on eBay or something.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
