Visio E371VL Tv turns on but within a few seconds of turning on, the screen gets lines and it makes a loud noise. I know these units are common for eeprom problems. Could this be an eeprom problem?
Visio E371VL Weird Picture at start
Re: Visio E371VL Weird Picture at start
I haven't picked up the tv yet. I was debating. I'm getting it for $20, so it's worth a shot to see if it's a cap problem. From what I was told, when it's in it's booting mode as the startup tone kicks in, it hangs, then the screen locks up. So the smeared screen is the Visio screen. I talked with someone that is very familiar with these units just before you replied and he said that the eeprom causes all kinds of grief but bad caps are not unheard of. I'll guess I'll find out tomorrow when I get it. I've spent more money on worse things than this. hehe
I just picked up the tv. Looks like there's more to it. I turned it on and the orange Visio light went to white but no screen came on. Now I don't see the orange standby light. I guess the psu is toast. I see there is no 12v going to the main from the psu. The caps look good though. Is there any common faults with these psu's?
Forget about the missing 12v. One of the cables wasn't seated fully. It's doing what the old owner said it's doing. I think it's US4 I want but I do have a US3, US4, UP16, UP10, and UA1. I wanna buy an eeprom just for my own piece of mind. I checked all the psu voltages now. It's reading fine and I've turned it off and on reading them at least 6 times.Last edited by dcapper; 01-05-2018, 10:47 PM.
No fix. It's works for a bit then I lose my voltages for a bit. Then it will turn on and then turn off. It's almost the exact same time when it does it. I click menu, then settings, then add channel, change it to 3 then I get a weird screen at the bottom then it shuts off. The caps look good.
EDIT: I am getting some weird voltages from the MUR640. 60v a side when the tv is off. Then it jumps to 300v but when the tv is on it's more like 140v. I'm thinking it's that MUR640. Is there any other diodes I should replace on this board?Last edited by dcapper; 01-10-2018, 02:18 PM.
Originally posted by dcapper View PostNo fix. It's works for a bit then I lose my voltages for a bit. Then it will turn on and then turn off. It's almost the exact same time when it does it. I click menu, then settings, then add channel, change it to 3 then I get a weird screen at the bottom then it shuts off. The caps look good.
It sounds like you are checking the Voltage on the hot side and use the chassis for GND ref for the meter which will be wrong.Never stop learning
At this point I doubt that the problem (Picture) you have has anything to do with the circuit in the hot side.Never stop learning
Although your MB is different model, see https://www.badcaps.net/forum/showthread.php?t=74561
and try the TV channel input on the main menu.....from your first pics you have the input set on RGB input
