Unknown Surface Mount Component
    I need to figure out what this is ... I've tried googling the identifier as I see it, but no love ... anyone know what this is?
    Re: Unknown Surface Mount Component
    so what is it part of?
      Bright single LED 4.5v flashlight.
        Here is the whole circuit:
          it's a chip - custom.
          did you remove some resistors?
          those chips only handle 1.4A, the board usually has some parallel resistors to limit the led current.
          if your trying to fix it, you can bypass it for 100% or off - no multi-mode.
            I have not removed anything from that circuit board ... thats all that was on there, those two components. I assume the little box is a resistor.
            What do you mean by "100% or off - no multi-mode"?
              Multi-Mode: Low beam, Medium beam, High beam, Strobe, and SOS modes.
              Or it has just ON and OFF.
                It appears to be flashlight LED controller + MCU. Some IC's have linear constant-current control and others have buck converter to do that for higher efficiency.
                My guess is YX8133A by shiningic but hell to translate. Replaced by YX8231B or YX8232B. I can't find much for SMD marking codes.
                If you have an inductor stashed away somewhere, it is a buck-converter type.
                  a better question, is what is the pcb diameter and how badly do you want to fix it?
                  there are better boards on ali-express.
                  do you know the led type? Q5? T6?
                    Oh - yeah ... it has High, Low, and Strobe, but I'd be ecstatic if I could make it just do HIGH and OFF.
                      The diameter of the PCB is exactly 20mm ... and I looked on the LED for ANY identifying markings, and I found none .... HOWEVER ... when I connect a 4.2 volt 18650 battery directly to the LED (no current limiting resistor at all), it lights up like an angel from heaven just popped in the room ... and it draws 1.5 amps which I feel is WAY TOO HOT to run that led ... but at least we know what it CAN do although it got hot so fast, I think it might burn out at that kind of continuous draw ... when I put a CC power supply on it at no more than 4.5 volts at 250ma its nice and bright..... if that tells you anything ...
                        https://www.ledgroupbuy.com/cree-model-comparison/
                        When you bought that flash light, what does the seller say/claim?
                          well a Q5 is 350mA and a T6 is 700mA - assuming your not overdriving them.
                          if it has zoom or you have a magnifier,
                          a Q5 has 3 rectangular segments and a T6 has 6.
                            So the LED looks exactly like these ...
                              seriously?
                              that's rare.
                              well they could be anything - .5w, 1w, or 3w
                                seriously?
                                that's rare.
                                It took a fully charged 18650 like a champ and managed to source 1.4 amps from it ... damn near burning my skin before it ever fried, so it's a pretty decent LED ... What I really want to do with this thing is power it from a couple of 18650's at a respectable brightness - maybe 200ma .... with just an on / off feature, no blinking or any of that fancy stuff. I might just stick with the LMN317 constant current config ... seems to be reliable although maybe a little too lossy ...
                                  then you need one of these:
                                  they are made for this job, if you want more current you just put 2 or more in parallel.
                                  you get a strip of 10 for under $2 on aliexpress.
                                    3.6V Voltage source feeding LM317 CC circuit to drive White LED (Vf of 3V @200aM) is not going to work because 317 has internal 1.25Vref, you will need more than 3.6V Voltage source.
                                    Build it and take some data.
                                      Thats why I was thinking of using TWO 18650's in series ... but what really bothers me about the LM317 option is all the waste ... id be recharging batteries too often ...
                                      STJ suggested the AMC7135 ... it looks pretty tight ...
                                        Page 4 of the AMC7135 spec sheet has the Pd calculation.
