Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 02-13-2019, 01:30 PM   #1
Trofazni
City & State: Kikinda
My Country: Serbia
I'm a: Knowledge Seeker
Default Samsung 24" power supply BN44-00195A
So, we meet again badcaps
I got monitor with psu mentioned, that was in some repair shop, but they tried something, with no sucess, and it came finnaly to my hands.
Problem was (or is still) on primary side, QM802/803 were short, as well as driver MC33067p, along with fuses, resistors, etc.
Changed all that I found faulty, but still it does not run. What you can see in a video, is psu+logic+pwr on/off button, without backlight or monitor connected.
As I switch it on, by pressing power button, pfc is working and steps up to ~390V, 5VSTB is steady, but 24V comes on very briefly. I detached 24-5V regultor, to eliminate problem in 5V rail, but is it the same situation.
When i switch it off, pfc drops, and that is it. I measured almost everything for shorts and values, can't find the problem...
Multimeter shows voltage of pfc, green is 5,2stby, upper is 24V, down is 5V meter..
Can anyone point me in some direction?
https://www.youtube.com/watch?v=iMELsqLluYE
Update: I checked voltages on MC33067, and i don't think there should be 14V on output pin 12?
Trofazni is offline   Reply With Quote
Old 02-13-2019, 02:42 PM   #2
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Samsung 24" power supply BN44-00195A
Check if CM808 is still good. It might be CM812 12n/630v
R_J is offline   Reply With Quote
Old 02-13-2019, 02:48 PM   #3
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
CM812 (Blue rectangular cap) is good? That schematic does not really match -00195A.
__________________
budm is offline   Reply With Quote
Old 02-13-2019, 05:31 PM   #4
Trofazni
My Country: Serbia
Quote:
Yes, tested it with one of those ebay "LCR-T4 ATmega328 Digital Transistor Tester LCD Capacity ESR Meter" which works really fine btw, cappacitance is 11n tested. Also CM809 47pF/1KV beside him is ok. Measured esr of electrolytic caps in that area, also ok.
When turned on by button press, MC33067 gets 15V, 24V rail gets some Voltage, and that is it. IC is still on steady 15V, but its like it does not oscilate. Also, changed that IC along with fet change, but i have soldered another one mc33067, and new ic does not make difference.
Next?
Correct me if I am wrong, but isn't MC33067 in charge of driving two fets that produce 24V over transformer?
Pins 12 and 14 are changing states giving impulses to tm802 trafo, wich are then rectified and limited and they drive gates of fets, one at a time, providing high frequency pulses, say voltage, to trafo that produces 24v. Well, this behave like it switches one just one fet for one time only. Although, optocoupler gets and loses voltage one time only, the driver ic 33067 still gets 15V steady,and stays on, regardles of no presence of voltage on diode part of optocoupler. Why ic stops sending pulses to the coil that drives fets?
Am I getting this right?
Old 02-15-2019, 09:27 AM   #5
Unspun01
City & State: Manitoba
My Country: Canada
Good job removing that crusty yellow adhesive glue stuff. That stuff was green on a few of my "Dong Yang" power boards in Samsung monitors and could possibly be conductive...double check you got all of it.
From the photo of the backside of your power supply board, check the condition of gate resistors RM813 and RM820. They look poorly soldered, and RM813 looks discolored possibly burned?. Should be 22 ohm.
Also check soldering of gate of QM803 for good connection or damaged trace.
Check coil continuity of transformer TM801. I don't know if it would happen here, but I had a small transformer with similar winding design that had an open winding on a different model Samsung 24" monitor. The transformer had one primary that drives 2 secondary windings, and one of the secondary windings was open.
Unspun01 is offline   Reply With Quote
Old 02-15-2019, 09:09 PM   #6
budm
budm's Avatar
My Country: USA
BTW, if the inverter board is not connected to the 24V output of the power supply, does the 24V stay at 24V?
Old 03-01-2019, 02:03 PM   #7
Trofazni
My Country: Serbia
It does not matter if it's connected or not... PSU should stay on even if inverter board is disconnected...
Quote:
They are ok. Problem is not that obvious, I THINK I checked all of usual suspects..
It's ok.
It's in the picture
Old 03-06-2019, 03:18 AM   #8
Trofazni
My Country: Serbia
Ok, so the problem was in one zener diode on error amplifier, it should be 27V, but it had leakage... 9V. Shouldn't pass voltage under 27. On multimeter testing diode has voltage drop within range, but voltage check did not go that well, and it reports fault in psu and shuts down.. Removed it, and put 2 zeners in series, 13V and 12V, and its working, and fault circuit is once again working You have details on pictures.. How i found it, when psu shuts down? I applied external 24V directrly to 24V psu rail, and measured... This is the first time I had problem like this, and I'm proud to say that i solved it
Old 03-06-2019, 10:53 AM   #9
budm
budm's Avatar
My Country: USA
Real good job finding the cause of the problem.
Old 03-06-2019, 01:17 PM   #10
Unspun01
My Country: Canada
Well done Trofazni! Thanks for posting your success so others can follow your steps.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
