Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Thread Tools Display Modes
Old 02-07-2019, 03:35 PM   #1
semperfio6
City & State: Chico, CA
My Country: United States
I'm a: Knowledge Seeker
Default EVGA GTX Titan Superclocks - Sheared off caps
Hey folks, I'm new here and was referred from a friend who does PC repair. Recently came across an EVGA Titan Superclocked (Keplar) that the previous owned knocked a couple caps off on the top of the board. Wondering if anyone can help me find the correct replacements for them so my buddy can solder them on for me. Attaching images for reference of the card area and the caps themselves.
semperfio6 is offline   Reply With Quote
Old 02-08-2019, 12:19 AM   #2
Sparkey55
City & State: OK
My Country: USA
I'm a: Professional Tech
Default Re: EVGA GTX Titan Superclocks - Sheared off caps
http://www.badcaps.net/store/product...products_id=76
This should work.
Sparkey55 is offline   Reply With Quote
Old 02-08-2019, 10:14 AM   #3
R_J
City & State: ☻
My Country: Canada
Or check digikey https://www.digikey.com/products/en/...=1&pageSize=25 and find the correct size (diameter/height)
R_J is online now   Reply With Quote
Old 02-10-2019, 09:39 PM   #4
semperfio6
Thanks to both of you, going to try the ones Sparkey55 linked and hopefully get this thing working
Old 02-10-2019, 09:42 PM   #5
Sparkey55
City & State: OK
My Country: USA
Quote:
Let us know how it turns out.
Old 02-12-2019, 08:36 PM   #6
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Quote:
Originally Posted by Sparkey55 View Post
Maybe...
Will work only if there is no restriction on height where those caps are located. Also, the caps you linked to are through-hole, whereas the originals are SMD. I myself prefer (and sometimes replace with) through-hole caps. But on video cards, height restrictions are often a factor. So the O/P may have to look on Digikey or Mouser for proper SMD replacements.
As for the original capacitors that got knocked there... 2.5V, 560 uF polymers. Hard to give a replacement recommendation, though, without knowing their height and diameter (in mm). Looks like 6.3 mm or 8 mm diameter polys. But I will wait for confirmation.
And if O/P has already bought those caps from BCN store... well, he could still use them on the card, if the rail these caps go to has traces on the back of the card too. Then simply just solder the caps on the back of the card. Not the prettiest thing to do, but should work.
Old 02-14-2019, 10:38 AM   #7
semperfio6
Quote:
Originally Posted by momaka View Post
Maybe...
You were correct, those caps were.... large heh. I should have paid attention and checked dimensions. Went on Digikey and found hopefully a suitable replacement, will check back in with end result.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
