Hello all!
I have been working at a Vizio vo47lfhdtv10a. I am at a point where I am confounded. I replaced 2 680uf 35v caps on both the slave and master that were bulged. Nothing. Then I found bad 470uf 35v under the heat shield on main power. I replaced it with a 1000uf 35v that I had. My understanding on that it is ok to go equal or higher. Still nothing. What has me baffled is I am supposed to have 0 voltage on pin 1 power on/off but I have 15.5v when tv is off but 3.13 when I power on. These were the readings even before I changed the caps. Any help?
Thank you,
Chris
Thank you,
Chris
