List of pin compatible Laptop ICs
This is a sticky topic.
    Re: List of pin compatible Laptop ICs
    Would anybody know if ATI 216-0772000 is compatible with ATI 216-0774007?
      K03J6 1M1 60D7 qfn mosfet can be replaced with?please help
        Hi, could anyone please tell me if LP2951CMX-3.3 or KF33BD-TR are compatible with P2808B0. I have a Gigabyte Q1732 that got struck by lightning and this IC is clearly KFC. I am able to de-solder and resolder but am finding it difficult to find the part in my neck of the woods. Any help would be awesome.
          i need equivalent for mosfet AON7200 in samsung NP270E5V
          i try with AP9402GYT but no result
          thanks
            Thaks a lot
              Originally posted by ala_borbe View Post
              anythin for MAX17005???
              Any replacement for Maxim MAX17005E??
                Hello
                what is the equivallent to BQ717
                  Hi all
                  Please someone knows equivalent for up1565p.it s memory voltage control on asus x751s mobo
                    Hi
                    Anybody know compatible chip with Richtek RT7238B / RT7238C.
                    From Quanta X22 Board.
                    Thank you.
                      51123 can't replaced by 51125
                      and no replace for max8731ae
                        LP6253H boost converter can anyone give me compatible replacement?
                          bios IC 3.3v and 1.8v ,KBC SIO, Laptop Ic list
                            Thank you, good resource.
                            A working TV? How boring!
                              just sharing hope it helps everyone
                                TPS51117=RT8209B RT8209A
                                Ao=ca AO=BM AO=CD AO=CA AO=BG AO=BG AO=CB AO=BL. AO=BG AO=BH FH=CG CU1 FH=EE FH=CC FH=DD FH=CL FH=8JFH=CF
                                TPS51123=RT8223M=UP1585QQAG RT8223BGQW RT8223B rt8223m
                                el=20 eq=cg eq=dm,eq=do eq=dd=da=dc=dk DS=CC DS=CD DS=CE DS=CF DS=BJ DS=BK
                                RT8205A=TPS51125 RT8205B=UP6182=RT8223
                                U1585QQAG=51123A=RT8223P
                                EM=EC EQ=XX
                                ISL6251 = G5209
                                ISL6237 MAX17020 MAX8778 TPS51427 RT8206B PM6686 SN608090
                                PM6686=TPS17020=isl6236=RT8206a=ISL62366
                                TPS51116=RT8207 ISL6227=APW7108 DH=CH DH=CA CP=DD CP=CF DH=EA CP=AJ
                                MAX8734A=RT8203
                                MAX1908=MAX8724
                                ISL88731=BQ24745
                                ISL6266=ISL6262
                                RT8204C= RT8204BGQW H6=CH H6=CB H6=CG H6=BE H6=CC FR=AH FR=AM
                                UP1585QQAG=TPS51123A=RT8223P DS=CC DS=CD DS=CE DS=CF DS=BJ DS=BK
                                KB9206QFC0 KB9206QFD2 KB9206QFD3
                                RT8207LGQW EF=CM EF=CG EF=CF EF EF=CM EF=DG EF=DE EF=CG EF=DF
                                RT8209A FH=CG FH=EE FH=CC FH=DD FH=CL FH=8J FH=CF
                                TPS51125A=RT8205BGQW CK=CD
                                RT9018B ES=EF ES=CL ES=DD
                                RT8207LGQW EF=DE
                                SN10504=SN0608098
                                MAX1908=MAX8724
                                ALC660=ALC883
                                ISL62883=ISL62882
                                IT8500E =IT8512E = IT8502E
                                P2805MF=G5933
                                Richtek laptop ic code
                                DJ= – RT8202AGQW
                                DJ- – RT8202APQW
                                DK- – RT8204PQW
                                JL= – RT8204AGQW
                                FR= – RT8204BGQW
                                H6= – RT8204CGQW
                                CJ= – RT8205AGQW
                                CK= – RT8205BGQW
                                CL= – RT8205CGQW
                                CB= – RT8205DGQW
                                DT= – RT8205EGQW
                                EM= – RT8205LGQW
                                EN= – RT8205MGQW
                                CP= – RT8207GQW
                                DH= – RT8207AGQW
                                EF= – RT8207LGQW
                                J7= – RT8207MGQW
                                DS= – RT8223BGQW
                                11= – RT8223NGQW
                                20 – RT8223PZQW
                                EP= – RT8223LGQW
                                EQ= – RT8223MGQW
                                FF= – RT8208AGQW
                                FG= – RT8208BGQW
                                H8= – RT8208DGQW
                                30= – RT8208EGQW
                                31= – RT8208FGQW
                                FH= – RT8209AGQW
                                A0= – RT8209BGQW
                                A3= – RT8209EGQW
                                JX= – RT8209LGQW
                                A8= – RT8209MGQW
                                K0= – RT8209NGQW
                                A6= – RT8209PGQW
                                EL= – RT8015A
                                DZ= – RT8113
                                CZ= – RT8561AGQW
                                D9= – RT9716AGQW
                                C7= – RT9293-20
                                  Originally posted by highpulse View Post
                                  51123 can be replaced by 51125
                                  naturly no
                                    which is max8771 equalant ic
                                      good information list thank you.
                                        hi can help me what is the equal or what can use for replace ?
                                        ncp6132a
                                        asbm1350g
                                        thanks
                                          any compatible for this chip GS7502Q3-R
