I have a monitor that has exactly the same source and the same control card, as your Westinghouse 19" LCD Monitor , but mine does not turned on, I check the voltage of the source 13.8v and 5v are ok. what can I do.
Acer AL1916W A LCD Monitor
Re: Acer AL1916W A LCD Monitor
I have found sometime a bad capacitor can keep a monitor from turning on at all.
You get no light at all from the power switch?
What brand of capacitors does it have?
I know it's the same board as that westinghouse but can you also take pictures of yours?^Learning to walk on rice paper without leaving a trace,
What is the uf and voltage of each.
I'm not pro but I will try to get enough information from you about your LCD so the pro's will have what they need to work with. Jacob^Learning to walk on rice paper without leaving a trace,
I would wait for conformation before proceeding. But,,, If I owned that monitor I would replace all 220uf, 470uf, and 1000uf Capacitors on the power board. 8 out of 10 monitors I see with those symptoms are repaired with cap replacement.
What year was it manufactured?^Learning to walk on rice paper without leaving a trace,
Originally posted by NamaI would wait for conformation before proceeding. But,,, If I owned that monitor I would replace all 220uf, 470uf, and 1000uf Capacitors on the power board. 8 out of 10 monitors I see with those symptoms are repaired with cap replacement.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Originally posted by telebrakeok I will buy, and make the change.There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- Intel Core i5-7600K 3.8GHz
- 16gb GSKILL TridentZ RGB DDR4-3200
- 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
- Windows 10 Pro x64
- GeForce GT1050
Absolutely no green led?Last edited by EGuevarae; 07-02-2009, 09:46 PM.There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
