Mbp 820 2936 board
Laptop came in with no green light.
Pp3v42 was shorted to ground. It turned out to be isl 6259.
I injected 2v@1amp on pp3v42 line and u7000 got worm.
I replaced u7000 and the board post has chime but not charging battery.
U7000 pin 17/18 3ohms pin 27/28 20ohms
Ppbus_g3h is 12.27v !!!
Green light appears after 3-4seconds it flickers a few times then it's solid green and fan starts to spin.
I tried to run ads test but it get stuck on loading asd ... board freezes mouse light goes off
I did reflow smc, no luck
Changed again u7000, no luck
I reballed smc, no luck
Smc data lines for u7000 are ok...
If i plug in battery+magsafe, when i disconnect magsafe, it runs from battery...
I never encountered this problem, ppbus 12.27 instead of 12.5+v and board posts
Thanks!
Thanks!
