Can someone please help me get the values of these capacitors I have posted. I believe one is 220uF at 25 volts. Please correct me or add your input. Thank you
Capacitor Identification
Re: Capacitor Identification
Thank you for the response. I am just beginning to work on this. Any help is appreciated. As I mentioned - the 14" screen on this is very hard to see. I can adjust the brightness with the Graphic Adapter but it still has a very low brightness level. Its just confusing. I hope to get it resolved--Thank you
PL3 and PL12 (the one with 2R5 written on it) seem to be both cracked.
These are inductors - big coils of wire wrapped around a metalic or magnetic core. If they're cracked and it's not by design, they may no longer work as intended but rather as weaker inductors.
PL3 is probably 150uH in value, the other one...I can't tell from the 2R5 code. However, you can't really replace it with any 150uH inductor, you need to know the peak current of that inductor (in Amps), the resistance (in mOhms)...
It would be best to get a service manual for this laptop or another model from the same series, and see what the service manual lists for these.
