Rescued an off brand 42" LCD tv from a local landfill today. Going through power supply and found an open fuse and a couple bulging caps. Tv does not power on at all, no light, nothing. Only thing possibly fishy is a closed 400v polyester foil capacitor. I am very inexperienced so can someone with knowledge tell me if these types of capacitors would normally appear shorted? If it is a problem what else should I check? Thanks
Poly Film Capacitor Bad?
Re: Poly Film Capacitor Bad?
There is no need to start multiple threads with the same question - let this one die and use the main one.
Resistor values - why not look them up yourself?
Type hobby hour resistor into your search engine.Please upload pictures using attachment function when ask for help on the repair
