toshiba satellite l50-B bios need
    hello everybody,
    I need the bios dump (EC+MAIN ) of this toshiba, motherboad number:
    DA0BLKMB6E0 REV: E
    thank
    Re: toshiba satellite l50-B bios need
    can you read your old bios and ec and post here
    i got main file, but ec is weird so id like to take look at your dump
    Im Back... sort of...
      thank you very much,
      here it is
        1kb file?
          this one is for Ec , my programmer did not detect the main chip 25l064c. thank you
            hello sir,Ala_borbe help me with the dump,
              hello everybody, still waiting for your help
                I cannot help if you dont dump your ec and post it here
                  here is ok 1k file
                    there is no 1k EC bios , even SIO is at least 32kb ...
                    but this machine somehow they have done that , strangely and no sense at all , but anyway , here it is both bios , and also your 25L64C bios is very recent low voltage chip , so you must try to find out a compatible ROM for low voltage with 64mb that can be read write by your programmer even if you need to make an adapter to reduce the voltage to 1,8V
                      24c08 is for password and serial num not for ec
                        toshiba satellite L50-B-27N PSKTQE-00E00GGR bios need
                          GD25LQ64 equivalent for 25L64C
                            If both 3v working if 1st 3v and 2nd 1.8v not working.
                              Hello I do need a bios binary for DA0BLIMB6F0, REV:F, from L50-B-1D5, PSKT4E. Should I try to flash E rev. ? Thanks!!
                                I need the bios dump of toshiba satellite C55-B1324 :
                                DA0BLKMB6E0 REV: E
                                  test plz
                                    DA0BLKMB6E0 REV: E
                                    test plz
                                      Ruslan657 Your bios file is 100% okkkkk... Thanks for uploading ........Have a nice Day
                                        Toshiba L50 -DA0BLKMB6E0 REV: E 100% Tested
