Constant current load for testing power supplies (guidelines)
    Re: Constant current load for testing power supplies (guidelines)
    I have a MOSFET load schematic i designed a few years back but never got around to building, i can share if you wish. It has only been simulated but it is such a basic circuit that it is guaranteed to work. It's based on the standard opamp + voltage reference + current shunt topology.
    A working TV? How boring!
      Yeah that would be interesting. That was the original point of this post: for people to come up with their own ideas and designs revolving around the main topic, since I'm sure there are various ways of achieving it, so perhaps in the end we'll combine all those ideas and end up with something that's both functional and revolutionary
      Wattevah...
        http://www.linear.com/solutions/1845
          budm
          This was interesting but what it lacks is what mosfet or transistors was used
          Do you have any clue what was used
          9 PC LCD Monitor
          6 LCD Flat Screen TV
          1 Dell Mother Board
          15 Computer Power Supply
          All of these had CAPs POOF
            Also, stupid question, but why so many resistors in series there ? 470mOhms times 4
            Wattevah...
              Has anyone else been messing around with this project ?
              Wattevah...
                Selfish answer: no, because I don't see any real use for it on my bench... The way I see it, a PSU needs to be able to deal with constantly varying loads, sometimes even in the kilohertz range. Since I don't need to accurately measure the limits of a PSU - just loading it down with light bulbs is sufficient to get a rough estimate of its capabilities.
                BTW, that linear.com sample idea for design, I would assume that:
                1. They used 4x470mΩ because you can now get 4x the wattage compared to one individual resistor of the size. Likely the smaller resistors are cheaper.
                2. Those transistors are probably not critical. Probably something like IRF520 will do.
                  Originally posted by sam_sam_sam View Post
                  budm
                  You ask about that?
                  Is on photo of schematic
                  Q1 Q2 2N3904
                  Q3 Q4 FQA140N10
                    Sch PDF, provided by Analog Devices.
