Re: Samsung SyncMaster 226BW
Samsung seems to have a reputation of putting filter caps with a voltage rating too close to operating voltage. I had a Samsung LCD TV that went out. The warranty service guy had a bag of 2200uF 50 vdc caps in his tool box to replace the stock 2200 uF 25 vdc cap in the power supply board.
The caps in the monitor p.s. board are the output filters of the switching power supply. I replaced mine with 35 volt parts to give them more margin.
The large 150 uF 450 volt cap is the main input filter that filters the rectified AC line input. The voltage rating is high to account for 240 vac line input (produces about 340 vdc). For U.S. 120 vac operation it has plenty of margin running at 170 vdc. If this cap is bad there would be nothing powering up (other then blue light which runs from a parallel low power supply).
