decorflame ndf-68n electric fireplace
    hi,is there anybody that have a shematic of this electric fireplace (decorflame)and insert is a ndf-68n
    it was brought to me all wire un-hook and a burn motor,so now i have the new motor but there are no diagram in it and i don't want to burn anything....
    so in this unit there a -
    -on/off switch
    -750 watts
    -1500 watts
    -temperature control
    -dimmer control
    -element/1 termal fuse
    -motor
    -small board with 5 wires that are all connect direct to dimmer switch,light and power.
    so if someone could give me a diagram even a drawing i would appreciat very much.
    Re: decorflame ndf-68n electric fireplace
    Show the data plata of your new motor in a photo and photo of the old motor
    Please make sure that when you enlarge the photo you can still read the data
    I might be able to help if I have this information
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
