Some "Vintage Iron" for you older PC guys
    Re: Some "Vintage Iron" for you older PC guys
    Originally posted by ChaosLegionnaire View Post
    oh no! aaaah! u've poisoned me with your fastest dual p3 gaming rig! why isnt teleportation invented yet?! i would want it teleported here. much easier to ship! lol~
    Shipping can be arranged. I got the case new, and still have its box & packing material.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      Because I felt like a challenge ... an image makes more that 1000 words...
        nice... 10mhz cpu... 80286 i guess? 1mb ram. not bad also...
          8086 more likely.
          286 would have started at 16 or 25MHz
            Plenty of 6, 8 and 10 MHz 286s. PC or XT class was usually 4.77 or 8 MHz. I've a few 10 MHz ones here.
              Just an update to this relic... Many moons ago, I was given a goodie box that happened to contain an Upgradeware Slot-T Tualatin adapter. I have a couple 1.26 Tualatin-S CPU's in the junk drawer....and curiosity got the better of me....
              It worked without issue. Now the problem, I need to find another one in order to run them dual.....that's easier said than done apparently....not a single one on ebay or amazon.
              ...but hey, how cool is this!!
              Yea, I've changed a few things around on this system...I removed one of the opticals and replaced it with a bay cooler for the 15K RPM cheetah that's in it. If I can find another Upgradeware Slot-T adapter, I'll grab a pair of 1.4GHz Tualatin-S processors, as those are plentiful & cheap....and will officially have this machine maxed out. Of course this message was posted from it.
              Team : 49813
              Join in!!
              Team Stats
                A few changes in this one.... I picked up a couple 1100/100 CPU's (SL5QW) and a couple Abit Slotket 3's (not easy to find). This creature is how running dual 1.1GHz. I never was able to keep it stable @ 133FSB, which isn't uncommon with the BX chipset. Now its maxed out. I'll snap some pics when I get a chance to install these CPU's..
                Team : 49813
                Join in!!
                Team Stats
                  Although it's in a ATX case (I used whatever I had around), here's a AMD K6-2 500MHz for you guys
                  Main rig:
                  Gigabyte B75M-D3H
                  Core i5-3470 3.60GHz
                  16GB DDR3-1600
                  Samsung SH-224AB DVD-RW
                  Delux MG760 case
                    Originally posted by Topcat View Post
                    A few changes in this one.... I picked up a couple 1100/100 CPU's (SL5QW) and a couple genuine Abit Slotket 3's (not easy to find). This creature is how running dual 1.1GHz. I never was able to keep it stable @ 133FSB, which isn't uncommon with the BX chipset. Now its maxed out. I'll snap some pics when I get a chance to install these CPU's.
                    You should have asked me. I have 4 new in box slockets in my junk drawer. IIRC 3 are MSI and one is ASUS.
                    sigpic
                    (Insert witty quote here)
                      I've got dozens of various/random slotkets (epox, msi, asus, and some other generics)....it seems very few support coppermines. I've been through a lot of them testing this. The Abit ones are quite rare it seems. The really rare one are the upgradeware slot-t slotket, which supports coppermines & Tualatins, and it did work in the P2B-D....but finding a mate to it seemed to be impossible. The one I've got came in a goodie box a few years ago. The only other I've found for sale is some moron on amazon wanting $130....umm, no. They don't turn up on ebay, I check regularly.
                      Team : 49813
                      Join in!!
                      Team Stats
                        Is that a rare bird? (the CPU being located at the bottom right on a K6-2-supporting motherboard)
                        (I only saw the CPU on the bottom right with Pentium I motherboards, for the P54s and likely P55s)
                        And my K6-2, rated at 450 Mhz, couldn't even OC to 500 Mhz, without crashing more than an airplane, FFS!
                        And also had stability issues, in a warm room, even when not OC'ing, FFS!
                        With that bullshit, I now wonder if I should have left it underclocked to 300 or 350 Mhz...
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        16 GB AData XPG Spectrix D41
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                          I wonder what happens if you install a more recent O.S. on this like Windows 7 and an SSD via a PCI SATA add-in card. Can you make it daily driver at that point?
                          Vintage Iron for me was a AMD K6-2 500MHz and due to financial constraints was stuck on that rig until I got a job and my first ever rig, a Sempron 2500+ and ECS N2U400-A setup.
                          CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
                          GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
                          Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
                            YMMV, but most MVP3 boards I've seen have it placed in the bottom right.
                            Then again, some have it placed differently.
                            Main rig:
                            Gigabyte B75M-D3H
                            16GB DDR3-1600
                            Delux MG760 case
                              My oldest (x86) box:
                              Compaq Portable III (~1987)
                              12MHz '286
                              640K RAM
                              20MB disk
                              1.2MB (5") floppy
                              2 slot (ISA) expansion case
                              Currently not in use but, rather, serving as a spare parts collection for my "considerably more useful" Compaq Portable 386:
                              20MHz '386
                              2MB RAM
                              300MB disk (I patched the BIOS to accommodate)
                              1.2MB (5") floppy
                              which is visually identical (except for branding)
                              The 386 nominally runs DOS and primarily hosts OpusV on an NS32032 coprocessor card sitting in the expansion chassis.
                                I have a 1400MHz PIII as my recording machine, it has Windows 2000 and Soundforge & CD-architect from the 90's. Sticker says P4, but I downgraded it 10 years ago as the older system worked better with the old programs... Two more boards in a closet as a spare parts. Update it, NEVER.
                                  I had a little free time this morning, so I put the finishing touches on this system's internals, and installed the 2x 1.1GHz (1100/100) SL5QW CPU's. These CPU's are very difficult to find. I got one in a junk box, but it took over 6 months to find the mate to it. Hardware-wise, this one is maxed out, and nothing is overclocked.
                                  This has been one of my favorite retro builds, for personal reasons....I had a P2B (housed in a case that I still own) when they first came out (celeron 266 @ 400 and then a 300a @ 450), but I was too poor for the P2B-D, let alone 2x real P2 CPU's. I've considered transferring this build into that original case...
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                    That thing looks like ot would be a screamer under Unix!
                                    Follow the white rabbit.
                                      my oh my....again!
                                      The P2B-D system went back into one of the best vintage cases I have.... It also got a RAID upgrade, a BRAND NEW AAA-131U2. I hated to cut the film off the retail box and open it....but its even more blasphemous to have a neat old controller like that, having never been used....I'm sure it was sad & lonely....but not now! A couple of the HDD's came from a hot dry place in the southwest, a couple were some I had on hand. This machine is orgasmic @ powerup, it sounds like a jet engine spinning up!
                                      The final specs:
                                      Asus P2B-D v1.06
                                      2x Very Rare 1.1GHz 100FSB P3 FCPGA (SL5QW)
                                      2x Abit Slotket III Adapters
                                      1gb PC-100 CAS2 memory
                                      3DFX Voodoo3500 GPU AGP
                                      Sound Blaster AWE64 audio
                                      SMC NIC
                                      Adaptec AAA-131U2 U2 SCSI RAID
                                      2x 36gb 15k RPM SCA HDDs in a mirror (OS)
                                      2x 146gb 15k RPM SCA HDDs in a mirror (storage)
                                      Plextor 40x 50-pin cdrom
                                      Plextor 12x4x 32 CDRW
                                      Iomega zip250
                                      Antec 430w PSU
                                      All the SCA HDD's are housed in icydock solid aluminum hot swap racks. These were new old stock I bought probably 15 years ago, and never used.....as SCSI was dying off back then, and I went with sata. This system is a small piece of personal history....definitely one of the finer pieces in the collection!
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                        It'd be awesome to have this rare beast, but I just don't have the money. Argh.
                                        Permanently Retired Systems:
                                        Kooky and Kool Systems
                                        sigpic
                                          That.... really puts my Soyo SY-6BA+IV to shame.
                                          Main rig:
                                          Gigabyte B75M-D3H
                                          16GB DDR3-1600
                                          Delux MG760 case
