Kenwood DNX6990HD service manual needed
    Re: Kenwood DNX6990HD service manual needed
    It is not exactly the same.
    I have only the DNX7190HD/DNX9990HD, but I believe that most of it, is the same as the DNX6990HD. They are just higher end ones, with more options on them.
    They were other models from the same generation, like the DNX5190HD, DNX6190HD.
    They are from the same year(same generation) though.
      Any sources for
      DNX891HD, DNX7710BT, DNX771HD, DNX691HD, DNX571HD, DNX571EX, DNX5710BT service manual?
        I only have the 570.
        You can most likely you can buy them from pacparts, or kenwoodparts. I have purchased these, for $20/each.
          I could not find any service manuals offered:
          DNX571HD search at PacParts
          Kenwoodparts.com
          store.kenwoodusa.com
          I'll try hit them up for it.
            You may have to ask them and most likely they will have it.
              Hi so you have dnx570hd service manual I could really use it
                Keep forgetting to find the disc, sorry, I will look for it, one of these days.
                  Here it is, sorry for the delay.
                    been looking for this for a long time, thanks
                      You were looking for the 571, no?
                      But I'm glad that I can help. You could have said something, because I had this for quite a while. I have purchased it, from pacparts.
                        Omg thank u so much tibimakia
                          good greetings
                          I'm looking for a dnn991hd manual ... or how to enter the hidden menu to reset the software.
                          I have a problem with the user
                            Most likely, you will need a service manual.
                            On these Android based receivers could be two passwords, one that every stereo could have, but with these there could be another one, Route Collector online credentials as well.
                            Think as with iCloud credentials, for an iPhone.
                            I have the same stereo in my car, by the way.
                            http://www.pacparts.com/model.cfm?mo...tion=list_part
                              thank you for attending my request,
                              the problem is the following I can not enter the operating system,
                              I have done the reset for the red triangle but the unit continues entering the menu of the photos ...
                              the person who sold me the unit told me the password of the user "batking" and with this user and password I enter the "route collector" page, but I can not access the system of the unit ..
                              It tells me that the password is incorrect or the service is not active.
                              I have asked the Kenwood service and they tell me that I must take the unit to the technical service so that with a code they can restart the unit.
                              Is it possible to access the system in another way?
                              Do you have another way of hard reset?
                                Unfortunately I don't know much about this.
                                You can try asking here, maybe somebody can help.
                                https://forum.xda-developers.com/sho....php?t=2268599
                                  ok thanks for the information I will try to look to see if I solve my problem
                                    Thank you so much I have the dnx891hd service if you need
                                      Thanks, for the offer. I have never had that model yet, but if I will have one, and need for service manual, I will be contacting you.
                                      I have issues, with my wife's 570, though. It turns on(fan is on), red triangular LED is on and the LCD backlight is turning on only.
                                      Not even sure, where to start with it.
                                        More possible info here - https://www.badcaps.net/forum/showthread.php?p=935350
                                        I found a Kenwood updater that is not their normal firmware update. It reloads everything on a few models including the 570HD.
                                          Anymore updates to this issue? Have the same model that is stuck in reboot. Took a heat gun to the board and now it works normally but only for about 5 minutes then goes into reboot. If I unplug it for a few hours works for 5 minutes then reboot and if I restart it without waiting goes straight to reboot.
