ShopJimmy LED Strip Rework Station - Single LED Replacement Tool
    Re: ShopJimmy LED Strip Rework Station - Single LED Replacement Tool
    Is this it? https://www.aliexpress.com/item/PTC-...27023b32CUMREi
      Originally posted by WhiteWolfHellas View Post
      Thanks for the reply, but the link is not working.
      Glad to hear no comebacks even after greatly heating up the new led. Do you lower the backlight after the repair in order for the leds to last longer?
      Apologies, I shortened all the tracking info from the link and trimmed too much.
      https://www.aliexpress.com/item/1pc-...974173898.html
      I remove the LED with the heater but depending on how much solder is left I then remove all the leaded solder and replace with lead free.
      When attaching a new LED it's staying well within reflow temperature parameters.
      Yes I turn down the back light.
        Do you replace the shorted LEDs, or do you replace every LED in the strip, even the good ones with new? Plus, isn't in more convinient to use liquid solder?
          Just the damaged ones usually.
          The LED strip is resting on a hotplate, the solder is liquid.
            Just the damaged ones only? Strange that you haven't got returns because the old ones tend to die shortly after. I have had returns by replacing just the damaged ones so I stopped using this repair method.
              Not really, after repairing the failed ones I run the backlights at 100% for 24 hours. Any further failures are replaced before they are turned down.
                Is it guaranteed that with this method (replacing just the dead ones and leaving the TV on at 100% backlight for 24 hours) the about to die old ones will die for sure? I mean what if you stress them and they die a week down the line? You'll have to repeat the proccess.
                  I warranty my work but nothing is every guaranteed, even new can fail.
                  If I stress them and they die in a week I replace them, but I haven't had to yet.
                    So, for example in a 10 led strips TV, only 3 leds are burned out. You just replace the 3 leds, leave the TV on at 100% backlight for 24 hours and if there are more to die, they die, you replace them and leave the TV on for another 24 hours? If it still works, you assemble the TV and call it a day?
                      I do use a bench power supply for my testing so perhaps they are failing then rather than with the TV powering then. I haven't had any failures when testing for 24 hours
                        https://www.aliexpress.com/item/32974173898.html
                        item #32974173898
                          They work better if the screws and feet are mounted the other way round so they raise the plate off the worktop and the narrow middle piece is used for the heat rather than the larger size.
                          I have a thermocouple jammed inside to get an idea of the temperature.
                          I intent do connect it to a PID and a relay for slightly better control but it doesn't burn FR4 unless it's left on too long.
                            They sure have lots of 230V version, 120V seems to be hard to come by on Ali.
                              Here is a 24 volt version of it
                              It not quite the same size but it should work
                              I ordered 10 of them
                              http://s.aliexpress.com/uie6nue2
                              9 PC LCD Monitor
                              6 LCD Flat Screen TV
                              1 Dell Mother Board
                              15 Computer Power Supply
                              All of these had CAPs POOF
                                Is it because they are not affected by the voltage difference ? I tried controlling my PTC with a variac but it still got the same temperature.
                                Yes can confirm, setting the voltage to 120V with my variac and the heater still gets to temperature.
                                Yes, I looked at those, then wondered how I would mount them.
                                  sale starts in 2 days - $4!!
                                    It was £3.50 at the beginning of the week. Nothing like putting the price up just before a sale !
                                      i said $, not £
                                        Thanks for testing it out at 120VAC, I will order a couple to play with.
