A customer at work brought his PC in not POSTing. I pulled the side off, and immediately noticed something that there was a pretty decent sized burn mark near the ATX power connector. It looks like a small surface mounted capacitor went up in flames. Initially, I thought that the board might be repairable, as I still have the poly-modded 945GCM5 board at home, so I could probably figure out what value it was. However, now that it's out of the case I don't think I'll bother. That cap has actually burned all the way through the PCB...
Another 945GCM5 - SMD capacitor burned through PCB
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProTags: None
Re: Another 945GCM5 - SMD capacitor burned through PCB
I've never seen that before. Was the PSU that was powering it bad? Is that a bulged Teapo at the top corner of the board?
The PSU was fine, actually. It was an In Win IP-S400CQ2-0. And yes, that El-cheapo Teapo cap in the corner there by the RAM is indeed bad, but there are enough caps that appear to be OK downstream of it in the VRM that I don't think it should stop it from POSTing.
I decided to clean some of the soot off the board. The pads for that SMD part are completely gone and there's a little crater in the PCB, and I can see what looks to be copper on the edges of it underneath the top layer, so I'm almost certain that other layers are damaged. I'll upload some pictures a bit later.Last edited by c_hegge; 02-04-2015, 11:31 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Saw the same thing in someone's LCD monitor in another thread. I guess where high currents are concerned, ceramics are just as bad as tantalums when they short!
Bet that one smells lovely."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn
ceramics can be worse, they short out like a lump of copper.
i'v had a tv where a shorted ceramic made a long track burn right up leaving not much more than a line of soot!
tantalums self-imiolate like a pissed-off indian, but ceramics put up a fight!
now i wonder what a failed Niobium cap does - because i am starting to see those in things.
Overvolt one and find outI love putting bad caps and flat batteries in fire and watching them explode!!
