Hello and nice to meet you to the forum! I bought this board with bad caps! the previous owner says that is not working at all! i bought it in order to do a full recap espacially on the vrm cirquit! it has nine OST capacitors 680uf 4v on the vrm and the bulged ones are 6. i was thinking of using the nichicon S8 series 560uf 6.3 volt with 0.008 esr in order to change all the Ost and i want to ask you if it is a good choice or may i buy some panasonic fm or fr which are cheaper but the efr is 0.056! i am asking you your opinion because i am afraid of the survival of this board but on the other side i have read in some posts here that these boards with g31 will survive with a recap! i am sorry for the only one blur picture,when i receive it i will take some much more quality ones! thank you very much!
Msi g31m3-f (ms-7528)
Re: Msi g31m3-f (ms-7528)
Go with the 560uF Nich S8 polies. I use 560uF polies to replace those 680uF OSTs on MSI boards all the time.I love putting bad caps and flat batteries in fire and watching them explode!!
Thank you very much for your repply "c hegge"! i will post again with my procedure! is it good to replace and all the kzg's at the same time? what is your opinion about the existing board? can these msi be survived only with a recap? thanks again!Last edited by tioklou; 01-21-2014, 04:29 PM.
If the board has KZGs (or TKs, Teapos, or any other OSTs), then definitely replace them too.
For the four taller ones which are near the rear IO ports, you can use 470uF 16V solid caps. I used Nichicon NE 470uF 16V on an identical board to this before, and it worked perfectly. (although you can leave them alone of they are Panasonic FJ or FL. I can't tell from the pic what they are).I love putting bad caps and flat batteries in fire and watching them explode!!
Originally posted by tioklou View PostOST capacitors were in terrible condition!!! they are the worst capacitors i have ever seen!!!
More like the photos folks were used to seeing during the old school badcaps.net times!Last edited by RJARRRPCGP; 01-25-2014, 06:56 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -Mà mismo
That's pretty common on those boards. The OSTs really don't like being placed directly under the CPU heatsink.I love putting bad caps and flat batteries in fire and watching them explode!!
You better replace them, thenI love putting bad caps and flat batteries in fire and watching them explode!!
