Another 945GCM5 - SMD capacitor burned through PCB
    A customer at work brought his PC in not POSTing. I pulled the side off, and immediately noticed something that there was a pretty decent sized burn mark near the ATX power connector. It looks like a small surface mounted capacitor went up in flames. Initially, I thought that the board might be repairable, as I still have the poly-modded 945GCM5 board at home, so I could probably figure out what value it was. However, now that it's out of the case I don't think I'll bother. That cap has actually burned all the way through the PCB...
    Re: Another 945GCM5 - SMD capacitor burned through PCB
    I've never seen that before. Was the PSU that was powering it bad? Is that a bulged Teapo at the top corner of the board?
    Yeah...Who knows what kind of damage occurred on the layers that you can't see.
      The PSU was fine, actually. It was an In Win IP-S400CQ2-0. And yes, that El-cheapo Teapo cap in the corner there by the RAM is indeed bad, but there are enough caps that appear to be OK downstream of it in the VRM that I don't think it should stop it from POSTing.
      I decided to clean some of the soot off the board. The pads for that SMD part are completely gone and there's a little crater in the PCB, and I can see what looks to be copper on the edges of it underneath the top layer, so I'm almost certain that other layers are damaged. I'll upload some pictures a bit later.
        As promised, here's the crater.
          Saw the same thing in someone's LCD monitor in another thread. I guess where high currents are concerned, ceramics are just as bad as tantalums when they short!
          Bet that one smells lovely.
          -David VanHorn
            ceramics can be worse, they short out like a lump of copper.
            i'v had a tv where a shorted ceramic made a long track burn right up leaving not much more than a line of soot!
            tantalums self-imiolate like a pissed-off indian, but ceramics put up a fight!
            now i wonder what a failed Niobium cap does - because i am starting to see those in things.
              Overvolt one and find out
                they dont come cheap you know!
