Ratdude's 3U Server Shenanigans
    Re: Ratdude's 3U Server Shenanigans
    Made some more purchases:
    http://www.ebay.com/itm/Top-Motor-DF...72.m2749.l2649
    That should quiet up the coolers while still providing excellent air flow when needed
    http://www.ebay.com/itm/Kingston-2GB...72.m2749.l2649
    Bought 6 2GB PC3200 sticks for $5 a pop shipped. 4 for the server, 2 for spares (since this will be system #4 for me that is running such RAM). Say what you want about kingston, but the four that didn't get nuked in storage run great in my wife's rig (which is also socket 940 with Opteron X2 285's). I'll happily buy more of those for peanuts.
    Now I'm waiting on PCBs to come in...
    sigpic
    (Insert witty quote here)
      I just bought some of those very same fans for the big black server.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        Did more debian configuration today... that is, moving the SAMBA share to the RAID array and resetting network interfaces. Tried to bond (mode 0, round robin) my two gigabit ports but the switch didn't like it (or there is something I screwed up. No bonding (aka teaming in windows) for me right now
        Also setup weekly backups to the former network drive since the RAID array is handling the actual shares.
        sigpic
          Did more looking, yup, the stupid switch isn't up to snuff for bonding. I'd need a managed switch to do that? Oh well, I tried.
          Edit- called topcat, nope. He has the exact same switch and teams just fine...
          sigpic
            I have 2 switches on my LAN. One is a Linksys SR2024, gigabit unmanaged. This is the switch that is directly connected to the NAS and the WAN router. My office (addition to the building) is on the 3com switch, which is basically stacked on the Linksys (yes I know, creates a bottleneck, but I'm working on changing that). There's a teamed system connected on each switch with no issues.
            Team : 49813
            Join in!!
            Team Stats
              Posted this on debian forums:
              Question:
              I'm trying to get bonding working on my new (to me) server. It uses a pair of broadcom netextreme gigabit ports (two different MAC adresses) for the bond (eth1 and eth2, eth0 is an intel 10/100 for 3 NICs on the mainboard).
              What happens is, after ifdown'ing eth0/1/2 and stopping /etc/init.d/networking, I change /etc/network/interfaces to have bonding. ifup'ing bond0 results in good results... but then starting /etc/init.d/networking eth1 and eth2 shut down (eth1 goes to 10/100 WOL, eth2 goes dead).
              Here's my /etc/network/interfaces:
              Code:
              # This file describes the network interfaces available on your system
              # and how to activate them. For more information, see interfaces(5).
              source /etc/network/interfaces.d/*
              # The loopback network interface
              auto lo
              iface lo inet loopback
              # The primary network interface
              #auto eth0
              #allow-hotplug eth0
              #iface eth0 inet dhcp
              auto bond0
              iface bond0 inet static
                  address 192.168.1.3
                  netmask 255.255.255.0
                  network 192.168.1.0
                  broadcast 192.168.1.255
                  gateway 192.168.1.1
                  bond-mode balance-rr
                  bond-miimon 100
                  bond-slaves eth1 eth2
                  #dns-* options are implemented by the resolvconf package, if installed
                  dns-nameservers 192.168.1.1
              auto eth1
              iface eth1 inet manual
                  bond-master bond0
              auto eth2
              iface eth2 inet manual
                  bond-master bond0
              and my /etc/udev/rules.d/70-persistent-net.rules
              Code:
              # This file was automatically generated by the /lib/udev/write_net_rules
              # program, run by the persistent-net-generator.rules rules file.
              # You can modify it, as long as you keep each rule on a single
              # line, and change only the value of the NAME= key.
              # PCI device 0x8086:0x1229 (e100)
              SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:e0:81:48:9a:64", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
              # PCI device 0x14e4:0x1648 (tg3)
              SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:e0:81:48:9a:28", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth1"
              SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:e0:81:48:9a:29", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth2"
              I do have ifenslave and non-free firmware installed. The bonded NICs shut down on startup.
              Is there something with /etc/init.d/networking that needs configured in addition to interfaces?
              sigpic
                What switch are you using ?
                  I think I fixed it. Apparently Ubuntu changed things and the "correct" way to run bonding on debian based systems (in balance-rr mode) is a bit different:
                  Here's my revised /etc/network/interfaces:
                  Code:
                  auto lo
                  #auto eth0
                  #allow-hotplug eth0
                  auto bond0
                      address 192.168.1.3
                      network 192.168.1.0
                      gateway 192.168.1.1
                      bond-miimon 100
                      bond-slaves none
                  auto eth1
                      bond-master bond0
                      bond-primary eth1 eth2
                  auto eth2
                      bond-master bond0
                  sigpic
                    https://www.badcaps.net/forum/showthread.php?t=63357
                    3Com Baseline 2824. 24 ports, unmanaged, full gigabit.
                    Did more testing last night, works great, 2.0gbs reported. Note to self: Instead of all interfaces being slave, all are primary with no slaves. Yay obsolete information persisting on the web...
                    If I was dumber and greedier, I'd nab a gigabit PCI-x card or two (I probably have one somewhere actually) and up the ante... nice thing about linux is that bonding doesn't care about brand of chip (although my card IIRC is also broadcom netextreme). But with only 24 ports, I'm probably asking for trouble by doing more bonds (or not, depends on how many cables to each room?). TC is running 4 on his twin servers, so I'm behind... but this isn't a competition? Or is is...
                    Ok, I've already lost... but who said I'm not competitive???
                    sigpic
                      Originally posted by ratdude747 View Post
                      If you first don't succeed, call it revision 1.
                      Here's revision 2, which acutally is NPN as called for in the intel PWM spec:
                      https://oshpark.com/shared_projects/C1SdRzD4
                      I also added a 5V full speed force jumper (JP2). It forces channel 2 to full, and also channel 1 if they're linked.
                      Better?
                      Bummer... Today I remembered something about KICAD: the TO220 pinout is wrong and pins 2 and 3 are backwards!
                      For testing at least, I'll probably be able to cross-leg the transistors, I hope.
                      In the mean time, I'll redo the board design and re-order them.
                      Doh!
                      sigpic
                        Ok, Here's Rev 3:
                        https://oshpark.com/shared_projects/V9E8DxQL
                        Changes:
                        • TO220 footprint fixed (Damn you KiCAD... and Damn me since I've already been burned on that before )
                        • Copper fill is ground, not 12V (no more warning needed)
                        • Swapped JP2 for a DPDT switch, like used on my Supermicro breakout board
                        I'll sleep on it before I order more... Did I mention I'm a dumbass?
                        sigpic
                          Another update:
                          https://oshpark.com/shared_projects/MdnDZqET
                          Changes:
                          • Added Screw holes in a 1.5" x 2.5" pattern (6-32 HDD/case screws and standoffs) as my old idea of using foam tape is probably doomed to fail
                          • Addeda bottom silkscreen layer as it's no longer getting taped (if you have a better message for the bottom, I'm open to funnier suggestions)
                          • Rechecked a print against real heatsinks to verify clearances (this was an issue with versions not posted)
                          Look good? As much as I hate it, I won't order until I have one of the V1 PCBs hacked together to verify the schematic.
                          sigpic
                            Did more looking... the Darlingtons use too much base current.
                            Looking at mosfets instead... found this:
                            https://electronics.stackexchange.co...ns-with-mosfet
                            Apparently when reading the intel spec I had things backwards? If it is indeed open collector, then that's the right circuit. I'll make a mosfet version based on that circuit.
                            Edit- Yup, confirmed. Mosfets and pullups it is.
                            sigpic
                              https://oshpark.com/shared_projects/zH7ELRHW
                              Changes:
                              • Conversion to a pulled up zener-based MOSFET Driver
                              • Removal of Force switch, as the pull up achieves the normal PWM fan function of no input= full blast
                              • Added a Tachometer passthrough to J8 and J11 via JP2 and JP3, as apparently some systems need the feedback to set base fan speed
                              • Took a tommy gun to it; due thin spots in the ground plane I decided to via stitch critical areas to increase current carrying capacity
                              sigpic
                                As for why/how I ended up barking up the wrong tree design-wise, I'm blaming the cesspool of bad information online and me missing a few critical design points.
                                A careful read of the Intel's spec for PWM (see attached file), especially page 9, cleared up a lot of the nonsense. Yup RTFM yet again.
                                Once I saw the sentence by itself saying "pull up to" in the Intel tech sheet, I saw what was really going on. Hence why I saw a lot of schematics with TIP120's and resistor bridges...
                                ...as for the move to MOSFET, that's because a tip122 only has a minimal gain of 1000. The intel spec limits the PWM input to a fan to 5mA... which for a spec'd load of 10A (a rough number I've used in the design), on both channels linked to one input we'd have a 10mA load. Since we have a pull-up circuit, that 10mA is over 7.3V (4.7V zener on the other side), which would be a 730 ohm ideal resistance. Since the input has to sink that, assuming a perfect 0V CE drop (worst case), that would be 16.4mA! Over 3x the current limit! However, the schematic I found online, when the output sinks, only has at most 4.44mA, which is close but not above the limit (what we want when designing a transistor/MOSFET driver).
                                Look good?
                                EDIT- FAIL. I'm going to make some changes.... As the driver will draw too much current to run another PWM signal off of it, I'm going to axe the PWM out ports and the jumpers.... and also move the tach ports and respace so PWM fan connectors will clear. Also seeing if I can half the resistance on the pull up resistors. Ugh. Here comes Rev 5!
                                sigpic
                                  Did a crap ton of math to find out that one driver per PWM is the max, and 2.4K is ideal (due to the relatively high 25kHz waveform used).
                                  So, I'll have to put in a 5A rated slide switch instead, as one of the Power MOSFETS can handle 10A in theory.
                                  Fun fun fun...
                                  sigpic
                                    ... and here we go:
                                    https://oshpark.com/shared_projects/Zx7VlDjY
                                    No more tommy gun via stitching... instead we have hobo patches (fill zones)...
                                    Look Good?
                                    sigpic
                                      Looks good in a picture....the tell-tale will be if it works.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                        We shall see.
                                        Found my old trusty (and never actually used for anything) Broadcom NetXtreme BCM5703X Gigabit PCI-X 133MHz card in the pile (read: sitting in a dormant Netfinity 7000) and decided to have some fun.
                                        That said, at least with this, the bonding setup is actually different than above... seems all my troubleshooting for 2 ports quit working, as the old file layout actually works:
                                        Code:
                                        auto lo
                                        #auto eth0
                                        #allow-hotplug eth0
                                        auto bond0
                                            address 192.168.1.3
                                            network 192.168.1.0
                                            gateway 192.168.1.1
                                            bond-miimon 100
                                            bond-slaves eth1 eth2 eth3
                                        auto eth1
                                        auto eth2
                                        auto eth3
                                        iface eth3 inet manual
                                        What was the real problem? Apparently ifup/ifsdown and the networking service do not agree and one shouldn't use use the former in debian. Either that, or the latter does the former when starting/stopping. The "new" file format was giving a bunch of "option primary not supported in balance-rr" errors when the service started, which hinted me towards reverting to the old format and skipping ifup (which did the trick).
                                        Something I wasn't sure about but seems to be doing OK is the usage of two 133MHz cards in both 133MHz slots... as the manual wasn't super clear on on if that would work... they "recommend using slot 1). lspci -vv is reporting 133mhz on all 3 gigabit NICs and also the 3ware 9550 too. So far, so good...
                                        Yay 1/8th of my switch is now used by my server... maybe I should have gone for a 48 port switch?
                                        sigpic
                                          You need one more...you're one gigabit NIC away from a tie.
                                          Team : 49813
                                          Join in!!
                                          Team Stats
