Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Audio Equipment Discussion
Thread Tools Display Modes
Old 11-12-2017, 03:38 AM   #1
Koprol
City & State: Emmeloord
My Country: The Netherlands
I'm a: Knowledge Seeker
Default Sony mds JA 30 ES minidisc
I have a fantastic but faulty machine from my brother. It's build like tank but is quite complex with a lot of pcb's and a complex disc mechanism.
I would like to repair it.
I understand most of you don't know this machine but it is "just another" electronic apparatus so you might be able to help me find the problem.
The loading tray wasn't working properly. I replaced the belt and that's solved.
Another problem occurs when the machine get warmer. When it is in my "cool" workplace it plays perfectly but in my audioset it sits above a warm poweramp. First the display goes black but the machine continues to work. Some time after that (30 min) it stops playing and doesn't accept minidiscs and spits them out again.
Koprol is offline   Reply With Quote
Old 11-12-2017, 05:00 AM   #2
jons
City & State: Riga
My Country: Latvia
Default Re: Sony mds JA 30 ES minidisc
Quote:
That sounds like cold solder somewhere, in power supply most likely. Check first hot components like regulators/diodes.
jons is offline   Reply With Quote
Old 11-12-2017, 06:43 AM   #3
Koprol
Ok, thanks.
I was going to search on the display pcb because the fault is is there first and then progresses to more areas. When writing this, your suggestion sound logical than mine...
Old 11-15-2017, 11:42 PM   #4
jons
City & State: Riga
My Country: Latvia
Still, check that displayboard also. There can be some more colds. Sorry for late answer, don't come here too often.
Old 01-20-2018, 03:53 AM   #5
Vitosev
City & State: Sevilla
My Country: Sevilla
hello, I'm having the same problem, when it's on for 30 minutes it's a strange thing and it's stopped, it does not open the tray, what was the solution? thank you very much
Vitosev is offline   Reply With Quote
Old 01-20-2018, 11:33 AM   #6
Longbow
City & State: Brighton, U.K.
Since the symptom can be reproduced, just get out your heat gun and find out what part of the unit is sensitive to heat. Or wait for failure and selectively freeze various things. Better than guessing at least for now. Usually mechanical things work better when they are warm, so I would suspect electronics first.
__________________
Is it plugged in?
Longbow is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
