Kada 852d+ need schematic
    Hello have this hotair and soldering iron station that is not work.
    have anybody schematic for it?
    Re: Kada 852d+ need schematic
    what is bad, the iron or the air?
    those combo units usually have a different board for each side.
      i allready modified this station wirh my own regulators to use only hot air because its iron is total crap
      but u know i want to learn so i want to repair this board
      i dont measure anything, because i want to first find schematic, if it is awailable
      on picture "SNIM" is marked sensors connectors and "ZHAV" is marked heating elements connectors
        if it's similar to the 858d then start with these.
          totally different, but its just one layer board so i can easy trace
          make some measurement and give feedback
            i realize there is triac missing so i replace it, but now i must measure resistance of temp sensor in heatgun to attach some resistor for testing
            do u think i can replace BTA08-600C with BT139-800 ?
            BTA08 - is 8A and trigger current 5-50mA
            BT139 - is 16A but trigger current is 5-10mA which im afraid of
              139 is better.
              btw, most soldering gear sensors are thermocouples, not resistors.
              they look like a short-circuit and generate a variable voltage that rises with temperature.
                139 is better.
                damn thats bad. there are voltages with temps marked on board but dont know if it is for hotair or iron
                  measure hotair and there are resistive sensor
                  so my test resistor would be 30-40ohm
                    Have anybody this station?
                    can u please photo its connectors? there are many same connectors and i dont know what goes where. so please upload me photo
                      and please one photo of secondary windings of transformer, because i found one wire disconnected
                        the transformer is usually 24v and 9v secondary's
                          i think i have 24V and 10V/its marked on board/, but i have there three windings.
                          one 24V i think because of thicker wire/iron power/ and two with thinner wire connected in the middle - see picture. dont know why it is the second thinner winding with loose wire
                          there is only 3 connection pads so maybe it is two 5V winding connected together to give 10V
                          that 1st picture have bad marks/yellow/ because 2x5V winding come in mind later
                            now i really dont know what to think about this chinese crap station
                            look at the picture with measurements
                              15v to rectify and drop to 12v/5v for the logic, 24vac for the iron.
                              2v probably not used here - but handy to drive VFD heaters!
                              is that original?? every station iv seen inside had wires coming out - no solder tabs.
                                must open station and cut whole cables to get out connectors and find out what is going where.
                                i connect 10V to connector marked 1/10V which i think is for logic and 24V to connector marked 24V for iron heater
                                dont know why this chinas engineer marked +/- on resistive sensor, and 24V IN/GND when it is AC voltage
                                and i forgot that this station dont have main switch so transformer is still working
                                looks like everything is working but dont have voltage on heating for hotair heater.
                                maybe it is because of my sensor replaced by resistorand test load is bulb, so i connect it right to the station.
                                but i will test it at the morning
                                  what are you doing???
                                  the soldering iron is 24v,
                                  the hot air is usually mains powered.
                                    that's exactly how i connected it. did u read something else from my post?
                                    looks like it is working. compressor is regulated, and sensor circuit works because when i turn of heater, compessor still works until sensor is cooled.
                                    But air heater is still on. i think that is something bad in regulation of it, because driver/MOC3023/ have still 1.16V between pins 1 and 2
                                      on my old one (no microcontroller) there was an opamp.
                                        and looks like we have a winner
                                        i take MOC3023 from iron heater and solder it to hotair heater and looks like its working.
                                        now i put everything to station and give a final test
