Biostar N7NCG 400 v7.2
    Re: Biostar N7NCG 400 v7.2
    Originally posted by BigTroll View Post
    I got a Enhance ATX-1136F its a 360 watt it was new old stock, I did open it and found jamicom and teapo it looked to be a 2006 build, I ran it on a PSU tester before i put it in the system. it seems to be doing fine but I will check the caps soon.
    I also got the FX5700 its a ASUS V9570, lubed the fan it had small rust spots on the dvi connector and looked like it was in a bit of water at one point but It ran 3dmark01se 700 plus tests before it locked up but that pretty good, it lasted at least 6 hours in 3dmark before crashing. I will continue to work on this system. and I appreciate your feedback everyone.
    Lower the aperature to 64MB, should increase the scores somewhat if not heavy pixel shaders running. Puts more work on the CPU. If you really want to test for heat buildup on the GPU run the Nature test in a constant loop. Be careful because that will stress the PSU even more. You might want to monitor the runs if doing that.
