Re: Manson hcs 3202
Be careful about disconnecting the feedback. By looking over the U5 data sheet, maybe you can tell what a reasonable dc level would be on pin 1. An easy test is to use dual trace. Hook trace 1 to the top of T2 primary, and trace 2 to the bottom of T2 primary and overlay the 2 waveforms. This test will show if TR2 primary is actually being driven differentially, or whether both ends have the same waveform, thus shutting down the supply.
By the way, what voltage does the front panel say? If it says 0 volts, then maybe the micro is doing its job!
