Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 01-20-2019, 08:53 AM   #1
frank123
City & State: Pozzuoli Campania/Naples
My Country: italy
Line Voltage: 220V
I'm a: Hobbyist Tech
Exclamation Dell Latitude E5450 Power Short Circuit
Hello to everyone
I have a problem with my Dell Latitude E5450.
When I insert the dell power jack into the laptop, the led on the jack turns immediately off, I tried with a different charger that does not have the self-ciruit test like the dell original adapter, and the laptop does not turn on, and no lights on the laptop.
I disassembled the motherboard from the laptop, and I don't know if this would be helpful but, I noticed that when i plug off the charger ( the non original one) from the motherboard, the CPU fan moves a little bit, but a little little bit.
I would be really grateful if you helped me, thank you so much
P.S. I enclose here the schematics of this laptop, the motherboard revision on this pdf is 0.3, on my motherboard is 1.0
File Type: pdf vinafix.vn_ZAM70 LA-A901P r03 Dell Latitude E5450.pdf (1.88 MB, 9 views)
frank123 is offline   Reply With Quote
Old 01-20-2019, 11:08 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Dell Latitude E5450 Power Short Circuit
try without the cpu.
stj is offline   Reply With Quote
Old 01-20-2019, 11:45 AM   #3
frank123
My Country: italy
Line Voltage: 220V
Quote:
The CPU is soldered
Old 01-20-2019, 02:24 PM   #4
stj
stj's Avatar
damn.
Old 01-20-2019, 04:04 PM   #5
heartbeat
City & State: middleport,ohio
My Country: usa
I'm a: Knowledge Seeker
it could be the power jack.while you got the motherboard out plug the power supply in and check to see if you have your voltage.
heartbeat is offline   Reply With Quote
Old 01-21-2019, 09:56 AM   #6
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
"When I insert the dell power jack into the laptop, the led on the jack turns immediately off"
so it work on battery?
check all big grey coils for short to ground
ktmmotocross is offline   Reply With Quote
Old 01-21-2019, 03:58 PM   #7
frank123
My Country: italy
Line Voltage: 220V
Grey coils are in good condition, the battery is low , so I am not able to test, but the laptop seems dead, I noticed with the other charger( that does not have the self-test circuit), the motherboard starts to heat up in around the area where the electric current enters
Old 01-21-2019, 04:38 PM   #8
ktmmotocross
Boardkiller
"Grey coils are in good condition"
i dont ask about it's condition
Old 01-22-2019, 07:58 AM   #9
SoporteHR
City & State: Barquisimeto / Lara
My Country: Venezuela
Line Voltage: 110VAC 60Hz.
Hi.
Check that the first Mosfet's and Diodes near the power supply jack are not short-circuited.
SoporteHR is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
