Thread Tools | Display Modes |
#1 |
Boardkiller
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
![]() hello.
have this sony_mbx-229_wistron_cadiz-cp_rev_-1m board with no power from main power mosfet. i measure that ACDET 2.6V signal is pulled down by AD_OFF_HW# from schematic i see that i need positive signal on pin 5 in Q68. But i dont find why it is not there. there are many ic U124,125,126 and i see some mark on SIO Nuvoton which i think is a burn mark. Do u think that bad sio can be behind no ACDET signal? |
#2 |
City & State: Neuss
My Country: Germany
I'm a: Knowledge Seeker
![]() hi
power it on with Battery ? |
#3 |
Boardkiller
![]() i charged battery with PSU to 12V but when i connected it i have only 3,3V on BAT ID and BAT IN# and 0,06V on BT+
as i see the BAT IN# must be low to start battery and it comes from SIO, so that burn mark on SIO can be my main problem do u think i can check other thinks by pulling down BAT IN# and start battery or i missed some signal that telling sio that battery is connected and charged? Last edited by ktmmotocross; 01-21-2019 at 03:44 PM.. |
#4 | |
City & State: Forbidden
My Country: Indonesia
Line Voltage: 220VAC 50Hz
![]() Quote:
Maybe that things have related with other voltage rails or 3V/5V rails. Sony vaio protection always make headache ![]() AFAIK I think AD_OFF_HW# issue cause SYS_PRS and U125 output need logic H, Check your RTC_BAT. Also the enable bat i think SYS_PRS#_1 need 0V. (already prove by your TIP thread, one cable connect to pin 7, right bro?) |
#5 |
City & State: Neuss
My Country: Germany
![]() Check with an psu Bench
give 19v on r2492 an how is amp Ithink Sio is defect Check if VCC or Vdd shorted |
#6 |
Boardkiller
![]() i think this was a mistake
found shorted both highside mosfets on 3,3 and 5V lines when i inject 3V to 3,3V line PCH start to heat up real quick and draw more than 2,5A 5V line looks good, it draw about 1A and it lowering when i desolder chips connected to it if all ic connected to 3,3V and 5V lines got hit from 19V, dont think it is refundable repair. but i save this laptop to time when i have another PCH to replace it |
Thread Tools | |
Display Modes | |
