Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 11-23-2018, 11:31 AM   #21
locojack
City & State: Buenos Aires
My Country: Argentina
I'm a: Knowledge Seeker
Default Re: Thermaltake ATX supply goes BANG! - TR2 RX-750
Does someone have the technical map of this power supply?
locojack is offline   Reply With Quote
Old 11-30-2018, 08:45 PM   #22
jazzie366
City & State: New York
My Country: United States
Line Voltage: 110v, 60hz, and a Variac.
I'm a: Hobbyist Tech
Is this not a skid mark around this transistor? I do believe whatever this is has puked it's guts.
__________________
Popcorn.
jazzie366 is offline   Reply With Quote
Old 12-01-2018, 04:51 AM   #23
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Quote:
Originally Posted by bcstedt View Post
Must be the lighting, I don't see any from here.
No
You have a lot of bad soldering joints when you see a ring around the joints those need to be reworked
I would recommend replacing all capacitors that are less than 100uf
at a minimum
It would be better if you replace all the caps except the the main capacitor
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is online now   Reply With Quote
Old 07-31-2020, 01:55 PM   #24
bcstedt
City & State: ON, Canada
I had to pack up this project due to moving and am now getting back into the stash. I'm doing some more inspection and measurements and will respond shortly.
Anyone else have experience with this model PSU or similar?
Thanks for all the suggestions thus far.
bcstedt is offline   Reply With Quote
Old 07-31-2020, 08:16 PM   #25
bcstedt
Quote:
Originally Posted by everell View Post
Measure the voltage across the 400 volt input capacitor. If it measures 166 volts, the APFC (active power factor correction) circuit is not working.
Input cap voltage is 167V.
Old 08-01-2020, 11:20 AM   #26
bcstedt
Quote:
Originally Posted by RJARRRPCGP View Post
I definitely notice a gap in the solder joint right under R7!
R7 looks okay to me.
Quote:
Originally Posted by Behemot View Post
Also check the input cap for bulging, the top is rounded. May be just the plastic but better be sure.
Just the plastic insulator on top, all the caps look good (not by brand though, obviously).
I'm going to check the transistors for shorts and see what shows up.
Old 08-01-2020, 11:50 AM   #27
RJARRRPCGP
City & State: North Springfield, Vermont
My Country: USA
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
It's below R7 and to the right of R6.
__________________
MSI B450 Tomahawk
Ryzen 7 "Matisse" 3700X
16 GB Corsair Vengeance LPX DDR4 SDRAM
XFX Radeon RX 580 8 GB
eVGA Supernova G3 750W
Received on November 4, 2019:
MSI GF63 Thin 9SC-649US
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 08-01-2020, 12:21 PM   #28
bcstedt
Yeah that's a shadow, little dip in the solder.
Old 08-01-2020, 01:32 PM   #29
bcstedt
Found some shorts!
Q7, Q8
D7, D?
Old 08-01-2020, 08:00 PM   #30
bcstedt
Well, I found some of the bang! Looks like R9 spilled it's guts because ... ?
Old 08-01-2020, 08:37 PM   #31
bcstedt
... Q5 and Q6 are shorted. 6R190C6
Old Yesterday, 04:57 AM   #32
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
and q5 & 6 are driven by what?
that has to be checked next
stj is offline   Reply With Quote
Old Yesterday, 12:35 PM   #33
bcstedt
Driven by CM6800G!
Any thoughts on replacing the 6r190c6 with 20N60C3 or FCP20N60 (ON Semi) or ... ? I'm searching for details on issues or reliability related to these FETs and found a few situations where these substitutions were made. Also, in one review of this PSU they show the 20N60C3 instead of the 6r190c6.
Just curious.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
