Delta EADP 260AP Psu problem
    Hi all,i have a problem when i start a ps3 fat and led flashes red,green and goes dead in a few seconds,it is a Delta EADP 260AP PSU,if anyone could give advice i would appreciate it
    Re: Psu problem
    so when it dies, is 5v still on the small connector??
    reason i ask, the psu is actually 2 psu's inside, the 12v one and the 5v one.
      Re: Psu problem
      There are 3 pins on the connector,which two must i short to power on the psu stj
        Re: Delta EADP 260AP Psu problem
        NOT 5v and ground!
        other than that - i dont know.
        i thought you had it back in the console - cant you meter the 3pin connector while it's in standby?
          I thought I answered this back in that thread:
          https://www.badcaps.net/forum/showpo...1&postcount=19
          Unsure why you needed the duplicate thread.
            Use 470 ~ 1K resistor between the two outer pins (PS-ON and +5VSB) to force on the 12V power supply.
            Delta EADP-260AP A
              Notes: you need to disconnect the connector to the main board to force on the power supply.
                Thank you gentlemen your input is highly appreciated
