Hello to all fellas
i have dell E176FPb monitor no power. i open the monitor and checked the primary voltage no power and i used a multi-tester. to check for resistance, i find a fuse has been (open) i remove it and i changes a new one and i try to power on again automatically the fuse (open) T2ah/250v. i think they have problem in hot area and i already experience repair before but is not a same brand. i saw the capacitor blowted 100u/450v (c605) then i check the mosfet p7nk80zfp (Q601) then also i check the one resistor (r615) open.
here is picture
update... pic
i replace it as a same value...
1. T2ah/250v
2. capacitor blowted 100u/450v
3. mosfet p7nk80zfp (Q601)
4. resistor (r615)
result same as no power. but a new part i re test again ok.
and also the the voltage is high?
i check on AC supply Voltage
i check on DC supply Voltage
Here in Philippines Voltage Source 220V-240V AC.
the ac voltage has been 500+ voltage not normal and then in dc voltage 300+.
what part have a problem. may i know?
TIA...
here is picture
update... pic
1. T2ah/250v
4. resistor (r615)
TIA...
