Hello everybody Ive got a Gateway FPD2185W monitor that displays no picture Flashlight test didn't work. It has a constant blue light when turned on.
It had bad caps in the power supply which I replaced with Nichicon and United Chemi-Con capacitors. I also replaced the ones on the logic board.
Still the some problem...
checked voltages
5V rail 5.05V
12V rail 12.03V
15V rail? 14.4V
I measured 14.4V on the source pin of mosfets U301 and U304
I also checked the voltage regulators on the logic board
voltages were fine
I checked for shorts across the MOSFETs
G-S D-S G-D
U305 14.56M 7.13M O.L
U302 14.3M O.L 7.8M
U304 4.72k 12.9M 13M
U301 4.75k 12M 12.2M
Checked the transformer windings
primary secondary
T301 0.4ohm 160ohm
T302 0.5ohm 157ohm
T401 0.4ohm 223ohm
T402 0.5ohm 222ohm
T403 0.4ohm 225ohm
T405 0.5ohm 222ohm
T406 0.3ohm 220ohm
T404 0.5omh 223ohm
checked the states of the BL and N/F pins
BL=5v
N/F=0v
I looked up the part number of the inverter controller I checked pin 6,VDD, and found it was 0.6V hmm...what if I pulled pin 6 to 5V?
here is a video showing it
http://www.youtube.com/watch?v=Wfjej...ature=youtu.be
part number is BIT3193G
other pins
1=0v 16=0v
2=0v 15=0v
3=0v 14=0v
4=326mv 13=0v
5=0v 12=1.17v (should be 1.3v or higher according to datasheet)
6=283mv 11=0v
7=0v 10=0.616v
8=0v 9=0v
I think its a ccfl issue.
Please comment any help is appreciated!
checked voltages
5V rail 5.05V
12V rail 12.03V
15V rail? 14.4V
voltages were fine
G-S D-S G-D
U302 14.3M O.L 7.8M
primary secondary
T301 0.4ohm 160ohm
T302 0.5ohm 157ohm
T401 0.4ohm 223ohm
T402 0.5ohm 222ohm
T403 0.4ohm 225ohm
T405 0.5ohm 222ohm
T406 0.3ohm 220ohm
T404 0.5omh 223ohm
BL=5v
N/F=0v
other pins
1=0v 16=0v
2=0v 15=0v
3=0v 14=0v
4=326mv 13=0v
6=283mv 11=0v
7=0v 10=0.616v
8=0v 9=0v
