Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Thread Tools Display Modes
Old 03-31-2019, 06:21 PM   #1
bluto
City & State: Illinois
Default Whirlpool Refrigerator LED lights flickering
I have a Whirlpool side by side fridge that is not even 2.5 years old. Recently the LED lights inside the fridge and freezer started acting up. Instead of fading on when the door was opened, the lights would just flicker slightly. Closing the door and re-opening would seemingly fix the problem. The problem was intermittent, but I figured it was only going to get worse so I decided to do something about it.
After some Internet searches, I determined that I was not the only with with this problem. There were dozens of reports of the problems with the same light module as what is in my fridge (W10515058). There were people that said they light failed when the fridge was just 19 months old. Some folks said they replaced the flickering module (spending between $75-$150) and it failed again in a year or two. There were some helpful videos on removing the module that also had some dubious fix suggestions.
To start with, I removed the module following the instructions in this video: https://www.youtube.com/watch?v=pCY2iaOFgN8
The module has two connectors. The first provides 120v to the board to power the lights when either the fridge or freezer door is opened. The second connector provides DC power to the other lights in the bottom of the fridge and freezer. Once this module is removed, all lights in the fridge will not function.
Upon examining the module, the first thing that strikes me is how well it is made. It is a multi layer board with mainly SMD components. It also has a conformal coating over the board and all components. There is no fancy control logic chip, so I would surmise that the the fade-in effect is orchestrated by a simple resistor-capacitor timing circuit. And this board operates in a nice, constantly chilly environment for 15 to 20 seconds at a time... So what excuse does it have for not lasting 10+ years?
I am going to take a stab at this and say that the problem is with one of the electrolytic capacitors on the board. There are a total of three of these capacitors present, a 3.3uf 400v (C6) and 2x 100uf 50v (C7 + C8). The first one appears to be the primary side filtering capacitor as it is near the 120v connector and in between the 4 diodes that seem to be the rectifier. The issue that I see is that the brand of this capacitor is 'Lelon' which happens to be on our bad capacitor list here. The other two caps are 'Nichicon' which are on our good list.
EDIT: Replacing C6 did not solve the problem! I am still working to find a permanent fix and will update the thread when a solution is found.
bluto is offline   Reply With Quote
Old 04-01-2019, 03:05 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Whirlpool Refrigerator LED lights flickering
it's probably a bad led, i see the board is designed to take 2 different styles.
stj is offline   Reply With Quote
Old 04-01-2019, 05:36 PM   #3
bluto
Oh noes, the flickering is back today! Arrgh... I don't know what to do next.
Maybe isolate the fade in bit and just tie the gate voltage of that transistor to Vcc? I might have to buy another one so I can experiment on the original.
This thing really shouldn't fail en-mass like what I have seen online as described above.
@stj, I don't think it is a bad LED because all 4 along with the other two LED modules connected to the output port are all acting up at the same time (intermittently).
Old 04-01-2019, 05:56 PM   #4
stj
stj's Avatar
are the led's in series though??
Old 04-02-2019, 12:05 AM   #5
redwire
City & State: Alberta
My Country: Canada
I kinda thought an LED is to blame, see all four have the "black dot of death" in pics?
Maybe the primary cap failed and then it hiccuped and killed the LEDs. It's not like they run for very long or get hot (in a fridge), unless Whirlpool overdrives them.
It looks like the PCB uses SMD 5630 LED's with 4-pin package and thermal pad, around 1/2W ea. Also has footprints to take SMD 5050 6-pin LED with thermal pad. I'd order a bunch of new LEDs.
All that electronics to light up four LEDs with fade effect. 38 testpoints
redwire is offline   Reply With Quote
Old 04-15-2019, 12:04 AM   #6
Kenmore
City & State: Mission Viejo
My Country: United States
I'm a: Knowledge Seeker
Bluto -
I'm facing the exact same problem on a Kenmore fridge; apparently many domestic fridges used the same set of three Whirlpool LED PCBAs.
However, on my control board, R15 (LED side of the board) is obviously toasted. Since your R15 appears to re unaffected, could you tell me the value marked on your R15?
The adjacent R17 is unaffected, and is marked 910 ohms. I've done a lot of research on this problem, and others have reported both R15 and R17 as having been grossly overheated, enough to obliterate the markings. I have not been able to locate a schematic.
I'll take some photomicrographs of the toasted R15 on Monday, and post them here.
Kenmore is offline   Reply With Quote
Old 04-15-2019, 05:39 PM   #7
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
If you replace LEDs modules
I would recommend that you look at the specifications of the type LED that you will be using
and make sure that they are not being over driven by too much current and voltage you will need to know how these LEDs are wired this is going to be very important to know
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is online now   Reply With Quote
Old 04-16-2019, 09:51 PM   #8
bluto
Quote:
My R15 reads just under 138 ohms. It looks like the number is starting to blacken, I think the code number is 1370 which would be 137 ohm +/-1%
Old 08-06-2019, 11:30 AM   #9
Dave125
City & State: Hudson, OH
My Country: USA
Bluto -
did replacing R15 fix the problem?
Dave125 is offline   Reply With Quote
Old 08-12-2019, 09:23 AM   #10
Dave125
My Country: USA
a guy at work soldered on a 1.8kOhm resistor to replace the R15 resistor and the lights came on! I'll test it out in the fridge tonight
Old 08-12-2019, 09:24 AM   #11
hoonigan_elec_engineer_04
City & State: Canal Fulton
I replaced the R15 resistor with a 1.8k ohm resistor 1/4 watt. I was able to put resistor in its place without interfering with putting the lens cover back on. I touched up some suspect solder connections that may be cold solder joints hence the burnt marks on PCB board. I had to melt off the rubber coating until I could get some solder to roll on the connections.
Bluto -
hoonigan_elec_engineer_04 is offline   Reply With Quote
Old 08-12-2019, 09:26 AM   #12
Bluto -
Old 08-12-2019, 09:29 AM   #13
R15 is a 1.9k ohm resistor. I replaced it with a 1/4W 1.8k ohm resistor in its place and lights are working. See my recent post with pictures. I also touched up some possible cold solder connections too.
Old 08-12-2019, 09:36 AM   #14
Try replacing R15 with a 1/4 Watt 1.8k ohm resistor and touch up some solder connections that look a little suspect for a cold solder joint. See my recent post with pics.
Old 08-12-2019, 09:01 PM   #15
sam_sam_sam
My Country: USA
I am confused about this if the resistor has a marking that say 1370
and you get 137 ohms how do come up with 1.8k ohm that makes the LEDs start working again
Old 08-13-2019, 06:34 AM   #16
Dave125
My Country: USA
unfortunately when I tested the light in the fridge it flickers off and on, so I have a strobe light now. I may go with a homemade LED light strip
Old 08-13-2019, 10:20 AM   #17
R_J
City & State: ☻
My Country: Canada
Quote:
Try replacing the resistor R15 with the correct value of 137Ω. You can't use a 1.8k which is 10x what it should be and expect it to work.
R_J is offline   Reply With Quote
Old 08-17-2019, 09:10 PM   #18
bluto
I'm still following this thread.. I still get the intermittent flicker occasionally when opening the fridge. Cycling the door light switch plunger will quickly clear the problem. I have left the light cover off so the light is hanging by the wires. Once when it flickered I tried unplugging the output side connector and all the lights went out. So that pretty much confirms that the LEDs are in series.
Other than that, the problem is not bothering me enough to do anything else about it right now.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
