I have repaired an old Olivetti PC using a MSI MS-6178 MOBO with Intel Pentium IIIE, 667 MHz .
To turn it on, you had to wait 20 minutes after you plugged the power cable because there was a problem with a signal transistor on PS.
I had to add a 10K resistor between Base and Emitter because the Base was floating and the transistor stayed on for about 20 minutes blocking the PS.
It took me 5 hours to find out the problem but I couldn't give up because this PS is not standard but it is small and I don't have a replacement for it.
In the picture you can see a comparison between it and an Allied ATX PS.
Moreover on the PS there were 3 problems:
1) the ST-BY voltage was out of control at 5.6V, I have changed the feedback zener connected to the integrated power switch, it was a 24V and I have used a 18V in series with 4.7V to lower voltage at 5.1V,
2) a protection zener on 5V ST-BY was overheating because the voltage was out of control; the zener has burnt PCB and 2 caps;
3) some caps were completely opened.
On the MOBO there were some CHHSI caps bulged.
I have replaced all caps on MOBO and PS with Panasonic FM, I have installed 256MB RAM, it was only 64MB, and now the PC is working perfectly.
Here attached you can see the pictures with badcpas and after recapping.
Ok it is not a fantastic PC, it is slow and old, but it is good enough for the person is using it.
Ciao
Gianni
Ciao
Gianni
