hp 655 newton_br_hpc bios
    hello
    does someone happen to have bios dump for amd
    hp 655
    pn: 010172W00-600-G
    NEWTON_BR_HPC
    MV_MB_V1
    it turns on, blink 3 times, pause, blink 4 times and turn off
    3 times blink = ram, but i tried 3 modules, all same
    4 times blink = vga, reflowed but no change (apu vga, cpu soldered)
    tnx in advanced
    here is my not woking dump
    Im Back... sort of...
    Re: hp 655 newton_br_hpc bios
    That can be bad apu cpu,that ting has tendency to fail...
    here is your dump...
    ah sad vidim brat bosanac...
      thank you very much...
      i found two more dumps but no go
      in between testing laptop died completely
      giving up on this one...
      @Djosla
      aha brat bosanac se bori sa elektronikom
      ljep pozdrav za CG
        Hi
        Dead GPU heat it to confirm 150c older model always N/B
        Then a must to replace because it will fail again.
        Techman1025
          Hello i have the same Hp 655 and no display. I try reflow gpu/apu but no help. I can hear that laptop start windows but no display show. Is this need to replace apu/gpu or something else?
          ...the quieter you become the more you are able to hear...
            try another display, back light may be bad or lcd cable
              i just check HDMI and it work, but no display on LCD. I will try to check lcd and cable
                well i try with another lcd but same thing, can you advise what it coud be?
                  i check the LCD cable but i only get 19V, no other voltages on cable. Is this GPU fail?
                    HP 655 AMD bios dump 4MB
                    hi all are looking for a dump bios for hp 655 4 mb, on the site hp is 4.37MB and I do not know how to work it,
                    The machine sometimes turns on but does not show, sometimes it turns on for 3 seconds and goes off,
                    I wanted to flash the bios but I can not find it correct.
                    this is the corrupt dump done on the failed machine
                    Thanks to who helps me
                      Re: HP 655 AMD bios dump 4MB
                      Try this and report
                        Originally posted by mcplslg123 View Post
                        Try this and report
                        thanks, the file is from 4.37mb,
                        the backup is 4mb and is different
                        I have to change the file from 4.37 but I do not know how to do it
                        can you help me?
                          can you help me?
                          Is better to send board code i try.
                            P/N 010172W00-36V-G
                            Newton_br_hpc mv_mb_v1
                            thanks
                              P/N 010172W00-36V-G
                              thanks
                              Try here.
                                Try here.
                                thanks
                                I try to flas the bios, update after the post
                                  I programmed the bios, the notebook always does the same problem,
                                  I'm reballing the AMD chipset
                                  I see if I can make it work
                                    hi friends, I update the post saying that I reballed successfully on the amd chipset, the pc now works perfectly, the problem resided in the chipset, thanks to all for the support
                                      Originally posted by ala_borbe View Post
                                      hello
                                      hp 655
                                      pn: 010172W00-600-G
                                      NEWTON_BR_HPC
                                      MV_MB_V1
                                      tnx in advanced
                                      this bios work perfect it might be your gpu tested it
                                        hello
                                        hp 655
                                        pn: 010172W00-600-G
                                        NEWTON_BR_HPC
                                        MV_MB_V1
                                        tnx in advanced
                                        check fbs11 and fbs7 for gpu power if power is ok then replace gpu or reflow
