Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 06-14-2018, 11:44 PM   #1
TechGeek
Computer Geek
TechGeek's Avatar
City & State: Texas
Line Voltage: 122.5VAC@60hZ/200A
I'm a: Hardcore Geek
Question APC Smart-UPS 1000- Should I install active cooling?
Hey all. Just ran a manual on battery test just to see how well it'll hold the load.
It held the load fine (4 computers, a monitor, a D-Link switch, 2 routers, a clock, 3 incandescents, and a CFL), and it was around 76% load. I happened to take a look around the UPS because why not, and I noticed kind of a burning smell being emitted from the unit. No smoke or anything like that, just something getting hot.
Should I install a fan (or 2) in this unit? A few months ago, I did an automatic battery runtime calibration at FULL LOAD, and it passed that test fine, and it took around 20 minutes to wear the battery down to the point where the UPS stopped the calibration.
Anyone? Anything?
LOL.
Just a question.
For computer parts, go to Newegg.
For electrical stuff(pushbuttons, capacitors, etc), use Digikey.
Windows 10!? Oh yeah, that sorry excuse of an operating system that is more infuriating than someone crashing your car!
TVs repaired: Toshiba 32AV500U
Stereo Receivers brought back to life: 1(Fisher RS-1056)
Stereos/Stereo receivers to recap: Fisher RS-1056
TechGeek is offline   Reply With Quote
Old 06-15-2018, 04:28 AM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: APC Smart-UPS 1000- Should I install active cooling?
About a month ago I just took my smt-2200 totally apart after 3 years to blow all the dust out. Maybe dirt collected a bit inside...
My smt-750 has no fan installed and it doesn’t smell either.
Old 06-16-2018, 02:58 PM   #3
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
If you are able to fit a fan or two in then I would recommend this, when I get these in for servicing I usually fit fans if they are not installed to help with cooling as at loading there is a significant current draw on the low voltage side. If my math is correct to achieve 240 watts at 240 volts assuming a 100% efficiency is going to pull 20 amps on the 12 volt side or 10 amps if 24 volt.
Also inspect the PCB for heat stress and bad poor solder joints.
llonen is offline   Reply With Quote
Old 06-17-2018, 06:53 AM   #4
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
The APC Smart-UPS 1500 has a fan.
It might be possible to fit the same one, as they share the same case...
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
