Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 06-04-2018, 04:43 PM   #1
DJ_MIX
DJ_MIX's Avatar
Default Benchtop Pro MD95 Dremel Burnt resistor now works at Full speed only
Guys need your help.
I believe it got wet a bit which then cause it to only run at full speed, no longer can adjust speed.
Opened up and notice burn near resistor. I guess I need new resistor but what value? I did not test any further, I guess I can remove resistor and check.
Let me know what you think. Also what is ntc 60?
DJ_MIX is offline   Reply With Quote
Old 06-04-2018, 05:00 PM   #2
R_J
City & State: ☻
My Country: Canada
Default Re: Benchtop Pro MD95 Dremel Burnt resistor now works at Full speed only
I would guess the triac is shorted, looks like that resistors been running hot for a while and it may still be ok. Remove it and check its value, look and see if there are any values still visible on the resistor
R_J is offline   Reply With Quote
Old 06-04-2018, 05:52 PM   #3
DJ_MIX
DJ_MIX's Avatar
Remove it but didn't see any values on the resistor. It did measure 5.2 ohms with multi meter. Which one would be the triac?
Old 06-04-2018, 05:54 PM   #4
petehall347
City & State: worcester
My Country: United Kingdom
yes the triac is suspect . or the pot is damaged .. maybe still damp .
petehall347 is online now   Reply With Quote
Old 06-04-2018, 05:55 PM   #5
petehall347
triac is the one with 3 legs
Old 06-04-2018, 06:11 PM   #6
DJ_MIX
DJ_MIX's Avatar
Thanks Guys, the trace near the resistor was lifting so I glued it back. Once I but it back I will retest.
Old 06-04-2018, 06:47 PM   #7
R_J
City & State: ☻
My Country: Canada
Remove the old solder and resolder the resistor, if the trace is bad just replace it with a piece of wire, Provide the number off the triac (3 leg part) if there is one.
Old 06-05-2018, 03:18 PM   #8
redwire
City & State: Alberta
My Country: Canada
It looks like the speed controller was overloaded, cooked the resistor and triac. The NTC was useless, it was supposed to limit power.
Drew a schematic but not sure what the cooked R3 resistor's value is.
The circuit did not make sense unless there is a diac or something underneath the hot glue blob.
If you can give the resistor ohms and triac part number, I will update the sch.
File Type: png Dremel Speed Controller schematic MD95.PNG (59.9 KB, 10 views)
redwire is offline   Reply With Quote
Old 06-05-2018, 06:34 PM   #9
DJ_MIX
DJ_MIX's Avatar
WOW, thanks
The resistor is mwntion above at 5.2 ohms
triac is Z0409MF A149
Sorry had no time to mess with unit.
Old 06-05-2018, 07:00 PM   #10
R_J
City & State: ☻
My Country: Canada
It's very likely the triac shorted, that would cause the motor to run full speed
Old 06-06-2018, 05:16 PM   #11
DJ_MIX
DJ_MIX's Avatar
I will remove and try to test it.
Old 06-08-2018, 03:28 PM   #12
DJ_MIX
DJ_MIX's Avatar
Problem solved, appears it was the Pot, I cleaned it and now have variable speeds..
Old 06-08-2018, 04:32 PM   #13
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
If you can find a new pot I would recommend replacing it
It might do the same thing again
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
